Can a battery be over powered??
i have a problem that consis of.... when i push in my clutch the battery will make a (click) sound from the + terminal and all the dash lights go dim then regain power slowly. So when this happens i tap the + terminal with the battery connector and the power is restored the fule pump engages and the car will start can any one help me ?
..... thanks
:Adrian Hamilton:
..... thanks
:Adrian Hamilton:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Civicsi »</TD></TR><TR><TD CLASS="quote">yah a lil bit could it be the ground to the engin? or could it be corrision on the batter - terminal ?
it could be either, but you said you have to tap the power wire to get everything to come back on, so I would start there. Corrosion does not conduct electricity. Get a can of regular coke and slowly pour it over your + terminal. Coke eats away at the corrosion you have.
coke would work, but if u want to do it right get some baking soda and water mixed together.
but do this after you go to walmart and buy new battery terminals for like $5. cut the old ones off and bolt the new ones on, if you can't figure out how, then you don't belong driving, no offense.
then use the baking soda mix on your terminals and clean them nice, use a wire brush if u need to. hook everything back up, done.
951dc5
11
Jul 17, 2007 09:45 PM
thehatchninja
Apr 1, 2004 03:10 PM
vizsual00
Aug 11, 2003 11:48 AM
adrian hamilton:
