cyp sensor questions
Old Mar 8, 2002 | 07:46 AM
dohcsideSi's Avatar
Default cyp sensor questions
i already asked this in the egforum but in case they didn't know here it is...i put a 97 b18c1 into my friends 95 integra i have a cel i haven't run it on the scan tool but i know its the clyinder postion sensor cause i didn't hook it up. i was wondering if anybody knew the ecu pin location on a p28 for this sensor. thanks guys
Old Mar 8, 2002 | 09:16 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: cyp sensor questions (dohcsideSi)
I believe there the sensors are in different locations on the OBD2 vs. OBD1 engines.
[Modified by B18C-EJ1, 10:17 AM 3/8/2002]
Old Mar 8, 2002 | 04:22 PM
Kataku2K3's Avatar
Default Re: cyp sensor questions (B18C-EJ1)
The other sensor is on the oil pumps outer casing, it the CSFS. OBD2 cars have both sensors, but the CSFS only measures the rotational crankshaft speed.
Old Mar 9, 2002 | 09:50 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: cyp sensor questions (JDMspecEG6)
CSFS = Crank Shaft Fluctuation Sensor
Doesn't measure speed, it measures vibrations
Old Mar 10, 2002 | 06:18 AM
EE_Chris's Avatar
Are you sure it measures vibration?
I always thought the CKF (Crankshaft Fluctuation Sensor) was used to monitor crankshaft speed to detect misfires. If there was a misfire, the crankshaft would have SLOWED down, the sensor reports this to the ECU, and upon looking at the distributor siganls, it will also know which was the offensive cylinder.
Anyone else have info here?
auzzie1998
Dec 30, 2017 06:42 PM
Johnny_9
Engine Management and Tuning
Jan 15, 2013 11:17 PM
sapphire32
Oct 9, 2012 12:15 PM
street_ride14
Mar 2, 2009 09:17 AM
DA-VISION-763
Jul 5, 2008 03:36 PM
