obd2 swapped DA, sensor issue
Old Jul 3, 2008 | 07:01 PM
DA-VISION-763's Avatar
Default obd2 swapped DA, sensor issue
ok so my 92 DA has a 1998 b18b swap, ev erything works and runs great except one sensor..I beleive its called the air charge temp. sensor, is there anyway to make my obd1 sensor work and is there any damage that could be caused to my new motor by running without it??
Old Jul 4, 2008 | 08:37 AM
God-Driven's Avatar
air charge temp? we need to know the exact name of the sensor or at least where is it located at, the extra sensors on the 98 engine (obd2) is the crank sensor and the secondary Os sensor, what engine harness are you using?
Old Jul 5, 2008 | 03:36 PM
Default Re: obd2 swapped DA, sensor issue (DA-VISION-763)
the secondary OS sensor itd be then , its a sensor on the intake mani, and Im still using my obd1 harness-like I said..works great even without that sensor..so I guess if it wont cause me any damage running w/o Im not too worried
DCWOOD
Honda Civic (2001 - 2005)
Nov 7, 2013 11:48 AM
pleej
11
Jul 6, 2010 02:31 PM
PROJECT 91
Nov 19, 2006 02:41 PM
sneakypete
Mar 2, 2004 11:31 AM
