TRYING TO FIND ECU CODE WEB SITE.. HELP
Old Mar 8, 2002 | 07:29 AM
ZColeon's Avatar
New User
Default TRYING TO FIND ECU CODE WEB SITE.. HELP
SEARCHED ARCHIVED FILES NO LUCK, ANYONE KNOW IT OFF TOP OF YOUR HEAD.. THANKS
Old Mar 8, 2002 | 07:31 AM
wronghand's Avatar
Default Re: TRYING TO FIND ECU CODE WEB SITE.. HELP (ZColeon)
http://www.quickhonda.net/
You should find it here.
EP3_05's Avatar
http://www.hybrid.honda-perf.org/tech/codes.html
There you go.
Old Mar 8, 2002 | 12:58 PM
june's Avatar
Default Re: TRYING TO FIND ECU CODE WEB SITE.. HELP (Lil Cs Zc)
Code # Circuit or system Probable cause
0 Faulty ECU Inspect the number 1 fuse. Replace if necessary. Also check for open circuit in the YEL wire between the #1 fuse and the combination meter. If no open circuit is found, have the wiring harness checked at a dealer service department or other qualified repair shop.
1 Oxygen content Check oxygen sensor and replace if necessary.
3 and 5 Manifold Absolute Pressure Check MAP sensor and replace if necessary.
4 Crank angle sensor Check crank angle sensor and replace if necessary.
6 Coolant temperature Have the vehicle checked at a dealership service department.
7 Throttle angle Check throttle angle sensor and replace if necessary.
8 TDC Position Check crank angle sensor and replace if necessary
9 No. 1 cylinder position(1.6L) Check crank angle sensor and replace if necessary
10 Intake air temperature Check intake air temperature (TA) sensor and replace if necessary.
12 Exhaust Gas Recirculation System Check EGR valve and EGR system.
13 Atmospheric Pressure Have the vehicle checked at a dealership service department.
14 Electronic Air Control (EACV) Check electronic air control valve and replace if necessary.
15 Ignition output signal Possible faulty igniter.
16 Fuel injector Check fuel injection system.
17 Vehicle speed sensor Have the vehicle checked at a dealership service department.
19 Lock-up control solenoid valve (auto-tranny only) Have the vehicle checked at a dealership service department
20 Electric load Have the vehicle checked at a dealership service department
Rowdy Rod
Feb 13, 2012 05:12 AM
BanEL
Jun 4, 2009 06:07 AM
jdmek9spoon2008
Jul 6, 2008 09:29 PM
saywhat
Dec 5, 2004 09:41 PM
brian estrada
Apr 3, 2003 06:33 PM
