code p0135
Old Feb 11, 2012 | 08:05 AM
Rowdy Rod's Avatar
Default code p0135
Had the local auto parts store check my 96 accord for check engine light on. It came up with code p-0135, oxygen sensor heater circuit, bank 1, sensor 1.
Is this the one right next to the cylinder head on the manifold? My Haynes manual only shows codes in 2 numbers and is useless with this.
Old Feb 11, 2012 | 09:57 AM
Lost Again's Avatar
Default Re: code p0135
Bank 1 sensor 1 is the "pre cat".....sensor 2 is "post" cat.....so yes the one infront of the cat.
Old Feb 11, 2012 | 05:34 PM
ricebike's Avatar
make sure you check the wiring before/after you change out the sensor...
Old Feb 11, 2012 | 07:10 PM
bdmlilburn's Avatar
and make sure if you do replace the sensor to replace it with a denso unit. the bosch sensors blow. check the electrical connector for the sensor also.
Old Feb 11, 2012 | 10:41 PM
Crawler89's Avatar
X2
denso will cost more when ever you buy it, before or after the bosch fails. after checking the connector, look up which wire is the heater and check the resistance,usually if only a heater code a DMM will read OL or some K-ohms, that makes it bad. Most of the time an O2 sensor code is the sensor, not always. Diag and visual inspection always before buying parts.
Old Feb 11, 2012 | 10:48 PM
Crawler89's Avatar
terminal 3 and 4 should be 10-40ohms which I believe if you have the F22b will be the yellow/black and orange/black wires.
Old Feb 13, 2012 | 05:12 AM
Rowdy Rod's Avatar
I bought the Denso sensor and popped it in, reset the ecm and its good to go. Thanks for the help. I would never use Bosch parts. Even the autoparts guy says all the local shops ask for Denso parts.
antok86
Honda Civic (2001 - 2005)
18
Apr 30, 2012 07:03 PM
salaamq
Jan 7, 2012 05:56 PM
sam978
Apr 21, 2006 01:58 PM
boltnut
Jan 7, 2006 08:43 PM
