Suspension & Brakes Theory, alignment, spring rates....
axle problem?
Old Oct 30, 2005 | 03:54 PM
UltimX's Avatar
Default axle problem?
I'm having this loud "clunking" noise coming from somewhere up front of the car. I can't pinpoint where it's coming from. As I looked under the car all I saw was this:
In the first pic, you see the lower control arm where it connects to the steering rack. Where the bolt is, there was a bunch of grease and it was flung all around the axle in that area. So tranny side, under side of the tanny mount, etc.
On the second pic, its upside down but in the same situation of the pass mount where the grease is apparent.
Everything else checks out fine. This only happens when i'm below 10 mph and making a turn. So, does this indicate a bad axle?
Old Oct 30, 2005 | 04:04 PM
Quad-Damage's Avatar
Default Re: axle problem? (UltimX)
sounds like u have ripped your cv boot, u might as well just replace the whole axle
Old Oct 30, 2005 | 04:05 PM
UltimX's Avatar
Default Re: axle problem? (Quad-Damage)
the weird thing is that it doesn't even looked ripped. Which is why its tripping me out. Is it leaking past the boot then splattering everywhere?
Old Oct 30, 2005 | 05:55 PM
NTGR8D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">the weird thing is that it doesn't even looked ripped. Which is why its tripping me out. Is it leaking past the boot then splattering everywhere?</TD></TR></TABLE>
it doesn't "look" ripped, but it certainly is if there's axle grease all over your boot and rim. Axle grease doesn't just pop out of no where. Easiest fix is what Quad-Damage said, just replace the whole axle.
Old Oct 31, 2005 | 04:45 AM
Undercover_Skank's Avatar
theres probably just a small hole...same thing happened to me...just repalce the boot...or easier the whole axle
Old Oct 31, 2005 | 10:31 AM
UltimX's Avatar
Default Re: axle problem? (Undercover_Skank)
alright... good thing i bought new axles... hopefully it will cure the noise up front. stock SI's are 26 splines in front?
Old Nov 1, 2005 | 02:21 PM
UltimX's Avatar
Update:
Axles are changed and the noise is gone. I havn't driven it for a long time but time will tell if thats the problem. thanks guys
tunerkid7
Honda Civic (2001 - 2005)
Jul 12, 2007 11:12 AM
UltimX
17
Nov 1, 2005 02:17 PM
LANEVOIX
Mar 4, 2005 11:20 AM
Rocks
Jun 28, 2004 11:06 AM
