Lower ball joint???
Old Mar 8, 2002 | 02:12 AM
97hb's Avatar
Default Lower ball joint???
The bolt on the lowet ball joint has some crossed threads. The castle nut will only go on part way and then just turns the ball joint . Do I have to replace the lower ball joint? How do I get it out of the knuckle? At least my other side went on smooth . Thanks guys
Old Mar 8, 2002 | 04:11 AM
sohc_boy's Avatar
Default Re: Lower ball joint??? (97hb)
did u try using an impact gun?
Old Mar 8, 2002 | 06:40 AM
94CivicSi's Avatar
you could try and chase those threads first with the proper die and see if they clean up. Sorry, I don't know size and pitch off the top of my head.
I'm not sure you're going to be able to get that balljoint out on your own if that doesn't work.
usdmEHboy
10
Feb 4, 2009 10:27 PM
innes887
Apr 12, 2007 04:03 PM
djtony5
Mar 28, 2007 11:34 AM
rasinhell
Feb 3, 2005 01:47 PM
97hb
Mar 9, 2002 11:31 PM
