will a obd2 dizzy work on a obd1?
Old Oct 29, 2005 | 01:47 PM
ek_chris's Avatar
Default will a obd2 dizzy work on a obd1?
i've searchd and asked people and shops and no one can give me an answer that is 100% certain. I'm swaping a built d16z6 (obd1) in for my d16y8. And the z6 has no distrubator/plugs/wires. I'm going to run a chipped p28 ecu with a obd2 to obd1 conversion harness so I "believe" I can use the obd2a distrubator on my obd1 motor. I know I can use the same plugs and wires but the dist., I'm not too sure if it will work.
I'm swapping this in next weekend or the weekend after depending on how quickly I get my answer.
Modified by ek_chris at 3:01 PM 10/29/2005
Old Oct 29, 2005 | 02:09 PM
duggy's Avatar
Nope, unless you rewire it.
Old Oct 29, 2005 | 02:51 PM
ekb16's Avatar
u would need to do a conversion adapter harness for it
ek_chris's Avatar
okay thanks..
is this a difficult task? I'm trying to find a site where it tells me how to do it.. but I can't find one. Do you have a link you can send me?
Appreciate it.
Old Oct 29, 2005 | 03:00 PM
ek_chris's Avatar
okay thanks! I'm ordering a dist. adapter as we speak.
Old Oct 29, 2005 | 04:02 PM
da_dude's Avatar
I'm 100 percent sure you can use your obd2 dizzy into your d16z6 engine. As long as your car is obd2 then its all good. No wire cutting or anything. I use a obd1 on my d16y8 engine so it'll work.
Old Oct 30, 2005 | 01:02 PM
duggy's Avatar
Dude isn't that common sense?
Old Oct 30, 2005 | 01:30 PM
ek_chris's Avatar
Default Re: (duggy)
i will be running a p28 ecu though.
I believe i do need the distribator adapter.
Old Oct 30, 2005 | 05:22 PM
da_dude's Avatar
Its just plug and play. All you need to run the p28 ecu is the obd2 to obd1 harness. Thats all. The y8 is the same thing as a z6. Just that a y8 have a little more power. Like I said if your car have obd2 harness then use the obd2 dizzy. Simple.
Old Oct 30, 2005 | 05:25 PM
ek_chris's Avatar
Default Re: (keng_lee85)
are you sure?
99% of people said you need to re-wire the obd2a dist. I'm still looking on the net and I still can't find anything.. a link would help
Old Oct 31, 2005 | 07:33 AM
da_dude's Avatar
You have an obd2 car, right? I'm guessing you are since you are ek_chris. Ek are obd2. If so use the obd2 dizzy with your obd2 engine harness. Then only thing I can think of that need wiring is probably the vtec wire. I don't understand why you have to rewire you obd2 dizzy when your car is already obd2.
Old Oct 31, 2005 | 07:35 AM
da_dude's Avatar
Well, if you really wanna know just try it. Put the OBD2 dizzy in and start it.
Old Oct 31, 2005 | 08:29 AM
warrenRHD's Avatar
i have an OBD2 gsr swap in my 94civic, just get an ECU jumper, and harness... its not to hard, just sauder and plug
Old Oct 31, 2005 | 11:09 AM
ek_chris's Avatar
why would the vtec need wiring when it's obd1 and so is the ecu?
Old Oct 31, 2005 | 06:55 PM
da_dude's Avatar
Default Re: (ek_chris)
Well if your car was an ex or hx you wouldn't need to wire your vtec but if it is a dx, lx, or cx you will need to wire the vtec from the vtec solenoid to your ecu cause it wont have it on the engine harness. If you car is an ex or hx you don't need to worry about it.
TwotoneC1Da9
Sep 28, 2010 07:38 AM
Theperfectsin
10
Mar 26, 2010 12:09 PM
soon2bdropped
Aug 30, 2007 10:32 AM
aarontrini85
Jun 5, 2007 01:15 PM
JMod
Feb 13, 2005 10:58 AM
