High HP cars with AC?
My boys puttin down 417whp with AC and theres been no cooling issues and the cars been running for well over a year in the hot Florida sun. Its an Inline Pro manifold, sc61 and 2.5" dp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue98Ex »</TD></TR><TR><TD CLASS="quote">My boys puttin down 417whp with AC and theres been no cooling issues and the cars been running for well over a year in the hot Florida sun. Its an Inline Pro manifold, sc61 and 2.5" dp</TD></TR></TABLE>
what rad is he using, etc.
anyone else?
anyone else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik B »</TD></TR><TR><TD CLASS="quote">i made 491whp with ac. Rev hard cast mani, sc61 and 2.5 inch dp flared to 3 inches after it clears the ac unit</TD></TR></TABLE>
awesome. I am using a inline pro mani but a lot of locals told me I will have over heating issues if I keep the AC and shoot for 500+whp and drive it on the street. I think I am goin to use a spoolin 3" DP to clear the AC
350ish whp
3 inch downpipe
full race mani
I still have ac and daily drive. No overheat problem. IN FLORIDA ALSO!!
half size fluidyne.
3 inch downpipe
full race mani
half size fluidyne.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">with a half size radiator and a stock condenser, putting in a dual pusher fan setup would there be enough room for a intercooler?? size is 22x8x3</TD></TR></TABLE>
yes you have to put 2 small fans on the front of the condensor pushing and theres plenty of room ...you have to cut the support for the hood latch sometimes and trim some metal
yes U can pusher fan both and make them fit.
the real limitation is the diameter of the fan, not the depth when your setting them up as pushers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 »</TD></TR><TR><TD CLASS="quote">that is awesome you guys give me hope. Danny do you run a stock rad or a aftermarket set up?</TD></TR></TABLE>
I had a rev hard manifold making 400 hp before with ac and power steering and it was fine with the stock gsr radiator....
I have to run a half core fluidyne with my current setup..im removing the ac to run a top mount...
Alot of the overheating problems people were having were from closed deck sleeves like darton causing a restriction....with my golden eagle hd sleeves it runs a little hot but I can only tell if i look at the datalogs...it wont show on the gauge till you get to about 235 degrees...then it will go past half way
cooler thermostat will only delay it from heating up....youll find that with different ects and air intake temps it will completely screw up the tune...you can compensate with most good engine management systems but it takes a while to get it right... without a thermostat you will have a very wide range of temperatures...it will make it harder to tune
Only thing Im running that not stock cooling wise is a Mugen rad cap/thermo (which is pretty much nothing) and in hot *** Louisiana weather. No issues! You can try running 'Evans Coolant'...that ***** better then Water Wetter. You'll be OK man. I mean I wouldnt beat on it in 100 degree weather with the AC full blast and what not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">
yes you have to put 2 small fans on the front of the condensor pushing and theres plenty of room ...you have to cut the support for the hood latch sometimes and trim some metal</TD></TR></TABLE>
so there wont be any heating problems? i mean the air would have to go from the fans through the condenser to the radiator. And the Intercooler would be blocking air to the fans when air passes through the grill.
