how to check if engine is legit?
Old Mar 7, 2002 | 03:57 PM
ALLMOTOR18's Avatar
Default how to check if engine is legit?
ok.. this guy is trying to sell me engine... he says its legit, but i dont know if i should trust him.. i saw the engine and wrote the numbers down... can i check it is legit by those numbers or do i need the actual vin number?... thanks in advance..
Old Mar 7, 2002 | 05:10 PM
JKim0901's Avatar
Default Re: how to check if engine is legit? (GSRTypeR)
yea how do you check anyone with the info?? i would like to check mine also
Old Mar 7, 2002 | 05:23 PM
JV's Avatar
JV
Who?
Get the Vin and get somebody to run it for you............
Old Mar 7, 2002 | 05:43 PM
ALLMOTOR18's Avatar
see.. the guy only has the engine.. no VIN just a block.. is there a way to track a block # to specific car?
Old Mar 7, 2002 | 05:51 PM
JMX's Avatar
JMX
this is a little off topic for u guys ..but damn i feel for you guys who live in states wiht inspection and all that...emissions and checking the engines and all that sucks
here in FL it's do what ever nobody cares
Old Mar 7, 2002 | 06:43 PM
Erik_Pb_Foot's Avatar
New User
Default Re: how to check if engine is legit? (jmx2323)
haha, must be nice
Ask for the VIN the car came out of. That would be my first guess. I'm not sure if there is a VIN stamped on the block or head....
Old Mar 7, 2002 | 09:09 PM
B18poweredhatch's Avatar
Default Re: how to check if engine is legit? (94hondahybrid)
carfax.com it when u get it.
Old Mar 7, 2002 | 11:50 PM
akhom's Avatar
Default Re: how to check if engine is legit? (b18c1 dx)
I don't think they stamp any vin Info on the block or the head. As least I never seen it.
Only the newer 94+ tranny has a vin plate and can be removed if someone really wanted to.
Yeah how do you check, is there a way to run the serial number? Wheres the heads serial numbers?
~Andy~
Old Mar 8, 2002 | 01:15 AM
AzN_Flava's Avatar
Default Re: how to check if engine is legit? (akhom)
Yes I too would like to know where the number on the head is... i see so many R heads gsr heads b16 heads for sale... but i dunno how ppl tell if its a good or bad one...
ummm how can you take a number off a tranny? aint it illegal just with it off even if its yours? like if you take numbers off your own block or car.. aitn that illegal? so wouldnt that apply to tranny?
Old Mar 8, 2002 | 07:35 PM
DoobieEF8's Avatar
Default Re: how to check if engine is legit? (AzN_Flava)
on a USDM b18c1 there is a little blueish green VIN plaque that looks similar to the tranny vin plaque right above the oil pan under the exhaust manifold. Im not sure whether b16a's have em. IF its a JDM motor you wont be able to check if its legit.
In california the only way to run numbers is to bring it to chp , if its hot they take it from you.
Old Mar 8, 2002 | 09:38 PM
earl's Avatar
Default Re: how to check if engine is legit? (DoobieEF8)
That's correct. The trick is to go to chp with the guy that you are buying the engine from. Run the #'s. If it's hot, let them take it from him BEFORE you pay for it. If he won't go to CHP, watch out. If the #'s are ground off, the CHP will take it just on principle. Happened to me with a tranny without a vin #, even though the tranny was older than when they began to stamp them. They didn't care.
I stamp everything myself now.
Old Mar 9, 2002 | 05:31 PM
AzN_Flava's Avatar
this is for the head and not the engine right?
Old Mar 10, 2002 | 07:52 PM
thejdmkid's Avatar
Ok if its a 96 an up usdm block it will have a vin. a 95 or 94 will be hard to trace. same with trannys a cylinder head cannot be traced why do u think all these e- bay theifs just sell the heads.
Old Mar 10, 2002 | 09:05 PM
bigTom's Avatar
Default Re: how to check if engine is legit? (thejdmkid)
exactly... there is no way to trace a head since there are no id/vin/serial #'s on them... 96 and up trannies and blocks have vin plates riveted into them... if there not there it is assummed that it is stolen...
fungus mungus
Apr 22, 2011 09:22 PM
junior_tm
Mar 30, 2009 06:07 PM
Dominicanstylz02
Jun 16, 2006 03:29 PM
shtalker
Oct 23, 2005 04:21 AM
LSVTEC408
Jul 30, 2002 09:53 PM
