putting 94+ b-series gears in a 92-93 tranny, is it possible?
Old Oct 26, 2005 | 07:41 AM
vtecn8ive's Avatar
Default putting 94+ b-series gears in a 92-93 tranny, is it possible?
I know there are similarities but I wasn't sure if I could just take everything out of a 94+ b-series hydro tranny and swap it into a 92-93 Cable tranny.
Any input? Or what can I use?
-shane
Old Oct 26, 2005 | 08:39 AM
Katman's Avatar
Default Re: putting 94+ b-series gears in a 92-93 tranny, is it possible? (vtecn8ive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">I know there are similarities but I wasn't sure if I could just take everything out of a 94+ b-series hydro tranny and swap it into a 92-93 Cable tranny.
-shane</TD></TR></TABLE>
yes this it is possible to put hydro B-series gearing into a YS1 transmision; you just might have to shave the inside of the cable tranny housing to fit a 94+ GSR or ITR final drive's ring gear though.
Old Oct 26, 2005 | 08:47 AM
vtecn8ive's Avatar
Default Re: putting 94+ b-series gears in a 92-93 tranny, is it possible? (Katman)
Which ys1 though? I got a ys1 from a 92-93 LS and I believe the tranny I got is either an ls or a sirII b16.
I know its not a type r doesn't have lsd.
Old Oct 26, 2005 | 08:53 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">Which ys1 though? I got a ys1 from a 92-93 LS and I believe the tranny I got is either an ls or a sirII b16.
I know its not a type r doesn't have lsd.</TD></TR></TABLE>
doesn't matter, all YS1's are capable of holding hydro gearing.'
here's a little fun fact, sonething you can chew:
YS1 LS gearing is exactly the same ratios etc. as hydro LS gearing, ring gear + diff size and all. Same with B16 hydro gearing minus the gear ratios tho.
Old Oct 26, 2005 | 08:55 AM
vtecn8ive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
YS1 LS gearing is exactly the same ratios etc. as hydro LS gearing, ring gear + diff size and all. Same with B16 hydro gearing minus the gear ratios tho.</TD></TR></TABLE>
Wow good info to know. Looks like I'll be making a hydro/cable tranny , I got the spare hydro and I got a ys1 that is just about toast!!
Thanks for the help.
Old Oct 28, 2005 | 05:42 AM
Katman's Avatar
no prablem and good luck...
ef-hatchcrap
Mar 9, 2009 09:16 AM
Bizarre
Jul 26, 2006 11:12 AM
zman
Apr 14, 2005 07:57 AM
KiLlInG 562
Apr 5, 2004 08:29 PM
SleepyEG
Mar 25, 2004 11:41 AM
