OBD2 motor into OBD1 car
Old Oct 25, 2005 | 04:56 PM
dorikingts's Avatar
Default OBD2 motor into OBD1 car
what do i need to make this work? i have a chance to get a OBD2 GSR motor from a friend, decently priced, and was wondering if it was worth it.
Old Oct 25, 2005 | 05:00 PM
Civicse's Avatar
Default Re: OBD2 motor into OBD1 car (dorikingts)
u'lll need the ecu and a conversion harness
Old Oct 25, 2005 | 05:37 PM
dorikingts's Avatar
what if i want to keep it OBD1? i already have a chipped p28, and all that jazz.
Old Oct 25, 2005 | 06:56 PM
dorikingts's Avatar
bump bump bump
Old Oct 25, 2005 | 06:59 PM
93turbo16's Avatar
If you can use all the OBD1 sensors and wiring harness, then it will plug right in.
Old Oct 25, 2005 | 07:04 PM
dorikingts's Avatar
distributor plug is the same? so ide need to use my map sensor, and all the little sensors like that?
Old Oct 25, 2005 | 08:00 PM
92civichatch1's Avatar
Default Re: (dorikingts)
well ur gonna get flamed for not searching but everyone at some point has asked this question and i have too.
Anyway you'll need an obd1 ecu and the obd2 engine harness from ur friends gsr put in the gsr and plug in the sensors then plug those big connectors at the shock towers in and your set. U dont need a conversion harness u dont need injectors u dont need a different dizzy. i dunno what car your puttin this in so u may have to wire up the vtec.
Old Oct 26, 2005 | 04:11 AM
dorikingts's Avatar
soooooooooooooooooo, alright, anyone else have any input?
Old Oct 26, 2005 | 04:31 AM
drtyhatch's Avatar
if your taking out the engine with the wiring harness on it, just bolt the engine in, plug up the wiring harness and put in your OBD1 Ecu. You don't have to change any sensors or any of that bullcrap.
Old Oct 26, 2005 | 07:52 AM
gftgrill's Avatar
I think his question is more, with the obd2 gsr motor, should he
a. use the obd2 wiring harness with a conversion harness and the obd1 ecu?
b. use his existing obd1 wiring harness with the obd1 ecu.
Old Oct 26, 2005 | 08:57 AM
93turbo16's Avatar
Default Re: (gftgrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill &raquo;</TD></TR><TR><TD CLASS="quote">I think his question is more, with the obd2 gsr motor, should he
b. use his existing obd1 wiring harness with the obd1 ecu.</TD></TR></TABLE>
You don't need a conversion harness, because the car is already wired internally for the OBD1 ecu.
Old Oct 26, 2005 | 10:30 AM
gftgrill's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
You don't need a conversion harness, because the car is already wired internally for the OBD1 ecu. </TD></TR></TABLE>
ok, thanks for the info.
MurtazaDSM
Aug 13, 2013 02:46 PM
appelsos
11
Jul 11, 2011 06:24 PM
mooseknuckle
Apr 5, 2004 06:05 PM
inline4
15
Sep 9, 2003 03:03 PM
TURBOED-TEG
Sep 14, 2002 02:28 PM
