B20 swap into an EK...can I keep the stock radiator?
Old Oct 25, 2005 | 02:50 PM
lowRIDAH's Avatar
Default B20 swap into an EK...can I keep the stock radiator?
ever since the swap the temp guage sometimes hits higher then normal but then goes back down when I'm moving.
is this because I'm using the stock rad?
if so which radiator should I change it to?
thanks
Old Oct 30, 2005 | 08:28 PM
lowRIDAH's Avatar
Old Oct 30, 2005 | 11:52 PM
ek99's Avatar
Default Re: (lowRIDAH)
Get an automatic one, its dual core.
Old Oct 31, 2005 | 06:01 PM
JDMFreak's Avatar
Default Re: (ek99)
yes, you can. i am running the stock 00 civic DX radiator. if you can get a auto dual core then that should be a plus! good luck!
Old Nov 2, 2005 | 10:16 PM
civicyellow's Avatar
should be ok, check if you have any air pockets in your coolant and make sure the fan turns on, i am pretty sure you just have to bleed your coolant
chrisfromsrq
Oct 14, 2009 11:52 AM
my00SI
Mar 20, 2009 06:23 PM
misternguyen
12
Aug 6, 2008 12:01 PM
kbaskett248
Nov 21, 2005 10:57 AM
Greasemonkey
31
Jan 5, 2005 07:10 AM
