What could cause low fuel pressure????
Old Oct 25, 2005 | 05:50 AM
Hecdosage's Avatar
Default What could cause low fuel pressure????
I put my head back together and turned the ignition on, the fuel pump activated but my fuel pressure was at 20psi. I was wondering if that was normal because I recall seeing it at 40psi but can't remember if it supposed to be low on idle and higher as the air pressure increases.
Old Oct 25, 2005 | 06:03 AM
JimBlake's Avatar
Default Re: What could cause low fuel pressure???? (Hecdosage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hecdosage &raquo;</TD></TR><TR><TD CLASS="quote">... supposed to be low on idle and higher as the air pressure increases.</TD></TR></TABLE>It's supposed to be lower at idle & higher as manifold pressure gets higher. But 20 psi sounds too low, IIRC...
Old Oct 25, 2005 | 06:31 AM
Hecdosage's Avatar
Default Re: What could cause low fuel pressure???? (JimBlake)
Thats what I thought But what could cause this?
Old Oct 25, 2005 | 08:10 AM
JimBlake's Avatar
FPR stuck open?
Fuel supply line crushed/kinked?
Fuel filter clogged?
Pulsation damper clogged?
Fuel pump worn & not putting out what it should?
You got the fuel pump to run, but did it sound OK? Slow? Anemic?
I'm gonna guess you didn't really do anything to the pump, supply line, or filter. But you must have taken the fuel rail off while doing the head. Since the FPR is at the return line, maybe it caught some dirt or something that you stirred up? The FPR is a back-pressure valve, so if it sticks open, the rail pressure goes down.
While you're there, make sure that gasoline isn't getting into the FPR's vacuum hose. That would indicate a ruptured diaphragm in the FPR, which would also cause the pressure do go down.
Old Oct 26, 2005 | 11:54 AM
Hecdosage's Avatar
I ran through all the processes of eliminations. And I discovered it was a faulty walbro fuel pump it turned on sounded strong but it turnrd out to be all bark and no good.
I replaced it with a spare and the car runs now.
eg6king!!!
Jan 27, 2012 03:05 PM
phelpsj2
Sep 20, 2011 08:06 AM
Tchleung
Oct 18, 2004 01:48 PM
E Swift
Nov 4, 2002 07:55 PM
Frcfedintegra
Mar 20, 2002 09:32 AM
