help sp job oh boy they did it again
Old Mar 7, 2002 | 11:16 AM
ludeboy's Avatar
Default help sp job oh boy they did it again
i have a 92 lude si with a h23 in it i put new vales,ti retainers,and after market springs,port and polished head,cams,and cam gears my car keeps reving up and down it gets worst hot the car gets intil it reves down and kills can anyone help me out here thanks
Old Mar 7, 2002 | 11:18 AM
laughinxxx's Avatar
New User
Default Re: help sp job oh boy they did it again (ludeboy)
Have you dyno'd it yet? I'm thinking cam timing or ignition timing.
Old Mar 7, 2002 | 11:21 AM
ludeboy's Avatar
Default Re: help sp job oh boy they did it again (laughin2.2)
no i havent yet the cams are set at 0 (stock) what do you think my timing should be at i al so have 75 shot zexs
Old Mar 7, 2002 | 11:27 AM
JG Luder's Avatar
check your vacuum hoses and TPS sensor. I've seen them need adjusting without throwing a #7 CEL.
Old Mar 7, 2002 | 11:28 AM
JG Luder's Avatar
Default Re: help sp job oh boy they did it again (Evil JG Luder)
Oh, and do me a huge favor... learn to use punctuation. It helps us understand your post a little better so we can help you.
Old Mar 7, 2002 | 11:30 AM
laughinxxx's Avatar
New User
3 degrees of retard. 2 per 50 shot.
Old Mar 7, 2002 | 11:41 AM
ludeboy's Avatar
well when i got the car. some vacuum lines where pluged off. so how do you think i shoud go about this. spmotor sports put a new h23 back init and they just hooked the old hoses back up.thats when the car start to do this.what should i do with the extra hoses that are cut off? the car ac was taken out and theres no cruise contol anymore or window wash pump.does that make a differnt?i took it to wilde honda and they couldnt fix it. they adjusted the idle but that didnt do anything. it started reving again about an hour later thanks
Old Mar 7, 2002 | 11:43 AM
ludeboy's Avatar
what you think the cams should be set at?
Old Mar 7, 2002 | 11:44 AM
ludeboy's Avatar
whats a #7cel
Old Mar 7, 2002 | 12:25 PM
freaker's Avatar
whats a #7cel
Check engine light.
Old Mar 7, 2002 | 02:43 PM
sisteve's Avatar
New User
Default Re: help sp job oh boy they did it again (freaker)
they should have capped off the vacuum line running to the cruise control on the manifold, if you have an open vacuum line, your car wont run, it'll rev up and down and eventually die. You might want to check the IACV also for carbon deposits, take the valve off and check the screen, if its covered in carbon, get some simple green and hose it down.
Id first check to make sure there are no open vacuum sources first.
JdmIntegra98
Jun 9, 2004 06:23 PM
GreenR
Jul 18, 2002 05:26 AM
RexB16
May 10, 2002 10:18 AM
