b16a2 idle/limp mode problem??
Old Oct 24, 2005 | 06:28 PM
thewonderer's Avatar
Default b16a2 idle/limp mode problem??
I got a 95 ex coupe just dropped a b16a2 into it. Im running a chipped p28 ecu on my stock harness. I did all the wiring. I cant figure out where i went wrong i need some suggestions. My IVAC EVAC EVaP MAP AND TPS SENSORS all are in functioning order. A friend suggested my injectors could be wired wrong. I had gsr cams in the head but when i swapped the cams back to norm the car still runs the same. I dunno what to try next ... gimme some pointers no flaming... thx
Old Oct 24, 2005 | 07:53 PM
blu3g's Avatar
Default Re: b16a2 idle/limp mode problem?? (thewonderer)
Check your FITV or your it could be that your timing is off.
ThefirstPACT's Avatar
Default Re: b16a2 idle/limp mode problem?? (blu3g)
Any codes?
Old Oct 25, 2005 | 10:31 AM
I checked timing.... I dunno wut fitv is. the codes are from my o2 sensor.
Old Oct 25, 2005 | 11:12 AM
Jay_Sensing's Avatar
FITV valve is located under your throttle body, search for it and there is one hell of a write up with pics on here for how to clean and re adjust.
If you are getting an O2 code, you could have wired it backwards as well. It happens a lot.
raverx3m
Apr 5, 2014 03:17 PM
JDM kid
Jan 15, 2013 09:30 AM
90dteg
Apr 6, 2009 02:31 PM
anthrax718
Nov 4, 2008 02:50 PM
mistake_2
Apr 22, 2003 08:08 AM
