Timing belt broke
Old Oct 24, 2005 | 03:51 PM
swindler86's Avatar
Default Timing belt broke
well the title pretty much sums up the situation. I was told that when the timing belts break that honda motors are notorious for bending valve stems or something like that. Is that true and what are some ways to check?
Old Oct 24, 2005 | 03:54 PM
high_revs's Avatar
single cam i think isnt interference motors, all the other ones are tho...most likely you bent a couple valves..
Old Oct 24, 2005 | 04:03 PM
swindler86's Avatar
that blows, any way to know for sure
Old Oct 24, 2005 | 04:05 PM
Stoich EG2's Avatar
Default Re: (swindler86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swindler86 &raquo;</TD></TR><TR><TD CLASS="quote">that blows, any way to know for sure</TD></TR></TABLE>
yes, pull the head.
Old Oct 24, 2005 | 04:07 PM
AMECustom's Avatar
Default Re: (ADVAN EG2)
no that were on this topic, can you ever really be safe from a belt breaking. I mean couldn't it just snap. And isnt the replacement time like 30000 miles or something
Old Oct 24, 2005 | 04:15 PM
Slow EJ8's Avatar
Default Re: Timing belt broke (swindler86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swindler86 &raquo;</TD></TR><TR><TD CLASS="quote"> well the title pretty much sums up the situation. I was told that when the timing belts break that honda motors are notorious for bending valve stems or something like that. Is that true and what are some ways to check?</TD></TR></TABLE>
i have heard that when the belt snaps it can bend valves. Pull the head and check or have a machanic do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMECustom &raquo;</TD></TR><TR><TD CLASS="quote">no that were on this topic, can you ever really be safe from a belt breaking. I mean couldn't it just snap. And isnt the replacement time like 30000 miles or something</TD></TR></TABLE>
the more miles the more likely it is to break. I havent heard of it happening before like 60,000 miles but who knows. Recomended change is like 60,000 to 90,000 or something. Def not 30,000.
Old Oct 24, 2005 | 04:20 PM
littlegreenb18's Avatar
i don't see how snapping your belt would NOT bend valves. some of them are going to be open, and with no timing belt, they are going to stay open, even when the pistons come up. so i wouldn't count on not having bent valves. the good part is replacement valves are not all that expensive, do it yourself, it isn't that hard. but i'd replace the valve seals too.
Old Oct 24, 2005 | 04:37 PM
aspec101's Avatar
follow maintenance guide and this kind of thing is easily avoided. Now pull the head off and access the damage. $30 belt vs. poss. valves, head gasket etc.
Old Oct 24, 2005 | 04:47 PM
swindler86's Avatar
ill tear the head off sometime this week when it stops rainin, and thanks for the help fellas
Old Oct 24, 2005 | 05:09 PM
Jay_Sensing's Avatar
Default Re: Timing belt broke (littlegreenb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlegreenb18 &raquo;</TD></TR><TR><TD CLASS="quote">i don't see how snapping your belt would NOT bend valves. some of them are going to be open, </TD></TR></TABLE>
Because as stated before, some engines are non interference engines meaning there is enough space in the combustion chamber for the crank to completely rotate with no belt and there be no valve interference.
Post which engine you have, you may in fact be lucky and not require anything mroe than a new timing belt and you will be back on the road.
Old Oct 24, 2005 | 05:17 PM
ThefirstPACT's Avatar
Default Re: Timing belt broke (Jay_Sensing)
why pull the head...throw a new belt on! If it starts up and sound good you're golden! If it dosn't what are you gonna do bend the valve more? You're gonna need a new belt so your not wasting money! I worked on a 88 or 89 four door civic and we just threw a belt on it after it broke it on the freeway and it started up just fine!! Give that a shot!
Old Oct 24, 2005 | 05:21 PM
LVB18Civic's Avatar
Default Re: Timing belt broke (ThefirstPACT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThefirstPACT &raquo;</TD></TR><TR><TD CLASS="quote">why pull the head...throw a new belt on! If it starts up and sound good you're golden! If it dosn't what are you gonna do bend the valve more? You're gonna need a new belt so your not wasting money! I worked on a 88 or 89 four door civic and we just threw a belt on it after it broke it on the freeway and it started up just fine!! Give that a shot! </TD></TR></TABLE>
I agree totally. I have worked on cars that have come into my shop with broken timing belts and sometimes the car is just fine after replacing the belt.
Old Oct 25, 2005 | 09:33 PM
swindler86's Avatar
kick ***, but im gonna need to find a timin light though, thsks again
Old Oct 25, 2005 | 09:37 PM
FERIOkid's Avatar
all honda motors are interference last time i checked which means the chanced of you having bent valves and possibly a warped head are quite high.
I would just buy a new head considering it is a d-series they go for like $50.
Good luck with everything
Old Oct 25, 2005 | 09:38 PM
swindler86's Avatar
oh and the motor is a d15z1
jaredvabeach
Jan 26, 2007 06:07 PM
00siandrew
Jul 20, 2006 10:13 PM
rpv173
Jul 23, 2005 10:19 PM
seerx
Nov 30, 2003 07:15 PM
E-Rok
Jun 19, 2003 10:04 AM
