97dx hatch rear disc conversion
Old Oct 24, 2005 | 01:59 PM
o0h5hitS0n's Avatar
Default 97dx hatch rear disc conversion
I want to convert to rear disc brakes and was wondering how big of a difference i'm going to notice under hard braking conditions? But what parts are needed? i'm assuming i could just use parts from an integra or si?
Old Oct 24, 2005 | 02:15 PM
ballplayer's Avatar
Default Re: 97dx hatch rear disc conversion (o0h5hitS0n)
First step..... search....you'll find all your answers
Old Oct 24, 2005 | 02:25 PM
JasonGhostz's Avatar
Braking system upgrades will only help you utilize more of the grip of your tires when stopping. Keep in mind that there is a difference between braking performance and stopping performance. What good will any braking upgrades be if your tires can't handle it, KWIM? If you already have really good tires, then either a big brake upgrade and/or drum/disc swap might be a logical progression.
But the OEM rear disc rotors are not that big, and you might be just as well off with really sticky tires and drums as with semi-sticky tires and discs... the drum brakes aren't that bad compared to the small OEM rear rotors.
Of course, disc brakes LOOK cooler, especially when you can see the glow through your wheels... a reason in itself to do it.
But I think it's best to start from the ground up... that's just me...
JasonGhostz
THC07
Suspension & Brakes
Feb 12, 2014 03:01 PM
aznsmtboy
Dec 7, 2007 04:36 AM
Syndacate
88
Jun 19, 2006 11:33 AM
parks
12
Dec 9, 2004 07:03 AM
mandelo
Jun 15, 2004 12:08 PM
