ruberized undercoating question
i got my new exhaust system installed and everything works great. the problem i have is the new pipeing is bigger and now sometimes rattles against the heatshield infront of the gas tank. I've had my car up on a lift and there is clearance but not much...and i can't bent the heatshield up or bend the exhaust down. would spraying a ruberized undercoating on this area at least lesten the rattle? I think it would but i'm also worried about the heat that would be there and if the stuff would melt or start on fire. If anyone has experience in this please post up
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cypher0117 »</TD></TR><TR><TD CLASS="quote">I think it would but i'm also worried about the heat that would be there and if the stuff would melt or start on fire. If anyone has experience in this please post up
took mine off. no problems with heat melting anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">took mine off. no problems with heat melting anything.</TD></TR></TABLE>
the one right by the gas tank? i've taken some of the other ones off and havn't had a prolem w/ them but about the fire thing i was talkinga bout the coating itself starting on fire if i sprayed that on
the one right by the gas tank? </TD></TR></TABLE>
yep. i guess you need to find a non-flammable coating if you don't want to lose the heatshield.
