SRI= Better top end vs. CAI?
I think CAI pulls better top end also but I have a friend who has built several mustang motors ( I know) and his car runs 11s all motor at 117 mph. He has been reserching motor theory for 10 years and he says the short ram should pull slightly harder cause the motor has to work a lilttle harder to pull air from the CAI.
He explaind it to me as if you were sucking water through a straw would you want a 1ft or a 5ft straw? I said the 1ft straw cause I would have to work less. He says the same concept applies to motors when it comes to CAI or SRI.
What do you guys think?
I doubt anyone has dyno numbers of both, since the difference is negligible. In theory though, SRI will move more air through the motor at high rpm's (more top-end), than a CAI (so a CAI should make more mid-range power). The question is whether or not the temp difference of the air will make up for the more restrictive design of the CAI. Either way, they are really close in power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">I doubt anyone has dyno numbers of both, since the difference is negligible. In theory though, SRI will move more air through the motor at high rpm's (more top-end), than a CAI (so a CAI should make more mid-range power). The question is whether or not the temp difference of the air will make up for the more restrictive design of the CAI. Either way, they are really close in power.</TD></TR></TABLE>
I agree . But if your driving down the freeway at say 70-80 ,mph it wont be TOO hot in the engine bay So SRI would be good for top end race in the senario. But at the track where your sits for a few mintutes or if you heat up the engine bay by doing a massive burnout before you run can result in the CAI making more power. So I guess there is good and bad in both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LDS »</TD></TR><TR><TD CLASS="quote">
I agree . But if your driving down the freeway at say 70-80 ,mph it wont be TOO hot in the engine bay So SRI would be good for top end race in the senario. But at the track where your sits for a few mintutes or if you heat up the engine bay by doing a massive burnout before you run can result in the CAI making more power. So I guess there is good and bad in both.</TD></TR></TABLE>
I run a SRI, at the track I take out my headlight and attach a velocity stack to the intake right behind where the headlight was. Best of both worlds for the track
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM »</TD></TR><TR><TD CLASS="quote">I run a SRI, at the track I take out my headlight and attach a velocity stack to the intake right behind where the headlight was. Best of both worlds for the track
.</TD></TR></TABLE>
yeah that works best imo...too bad i cant do it on the street without po po bothering me
.</TD></TR></TABLE>yeah that works best imo...too bad i cant do it on the street without po po bothering me
I did 2 SRIs (when the car was SOHC) to get the tube out the headlight cause I didnt have a velocity stack. Between the headlight tube and open header I gained 2 mph and .3 at the track but like i said, that was when i was SOHC. I cant wait to do that with the H motor. Yeah!!!
stevescivic
Jun 28, 2005 10:46 PM
Spade
Sep 16, 2002 11:11 AM
