LS swap into 99 EK Question
Old Oct 20, 2005 | 09:50 PM
b16ajdmrex's Avatar
Default LS swap into 99 EK Question
Which motor mounts do i HAVE to use??? or can i use the stock ones in there now and just get different bushings for them????
Old Oct 22, 2005 | 09:28 PM
Bgesy's Avatar
Default Re: LS swap into 99 EK Question (b16ajdmrex)
you can use all the stock mounts but you need to change the rear subframe mount to a 99-00 si
Old Oct 24, 2005 | 11:28 AM
SuperSlow's Avatar
I think you need #7.
I can't remember if there was anything else....
Old Oct 24, 2005 | 01:38 PM
Touge Tuning's Avatar
is ur car manual? If its manual you need #7 aswell you will need to change to the Si drivers side engine mount (bottom right corner of the picture above) and if you wanna keep your A/C you need #1 from a B20b/z.
If your car is auto you need #6 aswell.
MarTi E.K
Apr 5, 2008 10:22 AM
PHATFLIP
Jul 31, 2006 06:57 PM
SPOONfdEK
Aug 3, 2003 07:59 PM
civcexcoupeblack
Mar 20, 2003 06:46 PM
JDM CRX
17
May 29, 2002 10:23 PM
