Where to get t3 oil feed flange with 1/8" NPT threads?
Old Oct 20, 2005 | 06:53 PM
Justin Olson's Avatar
Default Where to get t3 oil feed flange with 1/8" NPT threads?
I've looked all around and can't find a oil feed flange for my turbo. I have a innovative gts58 and the housing is tapped for 1/4" npt. I dont want to run a -4 AN feed line. I need the 1/8" npt for my oil resitrictor to thread into.
Justin
This is pretty much what I want but it has metric threads.
http://www.atpturbo.com/Mercha...e=OIL
Function 7 oil feed flanges are nice but only come in -4 an.
http://www.function-7.com/a0-turbo.html
Old Oct 20, 2005 | 07:03 PM
mrbsponge's Avatar
Old Oct 20, 2005 | 07:09 PM
Default Re: (mrbsponge)
The only one I see they carry is a 8mm X 1.25 thread. I need a 1/8" NPT.
Old Oct 20, 2005 | 07:29 PM
Sprockets's Avatar
Default Re: (Justin Olson)
I'm 99% sure that ATP is talking about the 2 - 8mm x 1.25 bolts used to secure the flange. The bolts in the Function 7 picture are that size. By the way, check your Function 7 link again, because they sell -3an flanges.
Old Oct 20, 2005 | 08:22 PM
HiProfile's Avatar
Default Re: Where to get t3 oil feed flange with 1/8" NPT threads? (Justin Olson)
If it's tapped for 1/4" npt and you want 1/8" npt, either:
1) buy a brass bushing from any hardware store (technicly, black iron would be better)
2) send me $10 and I'll make you one with a hacksaw, TiCN'ed tap, and 3/8" aluminum. She won't be dat dun prudy tho
Old Oct 22, 2005 | 03:52 AM
JSPECSIR's Avatar
Default Re: Where to get t3 oil feed flange with 1/8" NPT threads? (HiProfile)
function 7 has -3an feed flanges with and without oil restrictors.
Old Oct 22, 2005 | 07:12 AM
nota-eg's Avatar
Default Re: Where to get t3 oil feed flange with 1/8" NPT threads? (5THGENSI)
Buy the 1/4" flange and get 1/4"-1/8" fitting.
I'm kinda in the same boat as you. I bought a greddy oil adapter and all of the fittings are 1/8" BSPT. Only thing the hardware stores around here carry are 1/8" NPT so I had to order one off of some fitting site.
Old Oct 22, 2005 | 08:09 AM
PM-Performance's Avatar
Default Re: Where to get t3 oil feed flange with 1/8" NPT threads? (nota-eg)
simple fix. get the 1/4 to 1/8 adapter. and get a 1/8 to 3an or whatever size you want and step it. I did the same thing multiple times
Old Oct 22, 2005 | 09:30 PM
Default Re: Where to get t3 oil feed flange with 1/8" NPT threads? (itr206)
Does function 7 sell there -4 an fitting with a restrictor already built in? If so I'll go with that so I can run Earls Prolite 350 for all the lines.
I'm using -4 prolite for all mu vacuum lines anyway.
Justin
Old Oct 23, 2005 | 12:06 AM
shyboy817's Avatar
ask stan from fast-turbo.com
psycho_civic
Oct 29, 2003 10:43 AM
BoosterChair
Jul 16, 2003 10:03 PM
Pat
Apr 13, 2003 10:26 PM
boostin b16
Mar 15, 2003 05:44 PM
sutrusu
Aug 25, 2002 03:15 PM
