engine swap/Smog Question
Old Oct 20, 2005 | 10:35 AM
IWantAnEG's Avatar
Default engine swap/Smog Question
Hi I know my fair share about cars, but not to much about the engine swapping part (atleast whats legal). i was wondering would a car pass smog if there was a B16a USDM in an EG? Or even any other USDM motor. Thank you.
Old Oct 20, 2005 | 11:33 AM
EL Vap133's Avatar
Default Re: engine swap/Smog Question (IWantAnEG)
Unless you have a sticker under your hood from the CA State Ref, it will not pass the visual.
Old Oct 20, 2005 | 09:49 PM
littleredcivic's Avatar
Default Re: engine swap/Smog Question (EL Vap133)
you can swap a b16 and get it reffed, you will get the bar sticker. i have a b18b in my EG and have a bar sticker. the process takes under 1 hour and $98.25. make sure you have a cat, all the smog equipment, aftermarket equipment must have CARB EO numbers, your engine is the same emissions classification (CA/FED), your ECU is USDM, no air fuel ratio gauge ( i found this out when i got reffed), the year of the engine is the same year as your car or newer, and all OBD equipment for the engine or the car is present. it may be hard to find yourself a OBD1 B16 that is USDM, I don't think there are many Del Sol packages out there. You are better off trying to get a B18B or B18C in the EG... if you switch to OBD2 using a 99-00 SI ECU, you will have to wire in the diagnostic port. you can always call the BAR and ask questions or go on the website. if you already did the swap, take it to the ref and have him run it. if it fails, he will give you back a piece of paper and tell you exactly what you need to fix in order for it to pass. just to let you know, you might want to pretest the car before you take it to the ref...
Old Oct 21, 2005 | 10:18 AM
IWantAnEG's Avatar
thanks for the info
Old Oct 21, 2005 | 12:07 PM
Default Re: BAR
If you want some help checking out your car to see if it will pass the BAR, let me know. I used to work at a Honda independant shop that did smog testing, so I have access to the Mitchell books that the BAR ref will be using.
Spade
119
Nov 11, 2006 07:29 PM
CivicSiRX
58
Aug 13, 2005 07:37 AM
95EXcivicsleeper
Apr 23, 2004 09:56 AM
Filliam H. Muffman
22
Feb 13, 2004 02:45 PM
Honda_HatchEG
Dec 5, 2001 01:10 PM
