California Smog answers! *End all to all*
UPDATE!!! The JDM ITR intake manifold is the same as USDM!!
Let's get this over with shall we. Here are links, and stuff quoted from those links. YES, JDM engines will pass smog, they just need the USDM equivalent smog eqiupment.
BAR website....read through.
http://smogcheck.ca.gov/STDPAGE.ASP?...S-JAN_1994.HTM
CARB aftermarket guidelines.
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
Some may be asking is my modification legal. Well here you go, if it's not in this database then it's not legal.
http://www.arb.ca.gov/msprog/aftermk...es/devices.htm
Ref a B18C in a CX.
http://hybrid2.honda-perf.org/ref99.html
More smog stories....trial and errors.
http://hybrid2.honda-perf.org/tech/refstory.html
[Modified by Spade, 3:04 PM 1/14/2003]
Japanese Replacement Engines
Used engines imported from Japan can be used as replacement engines as long as the engine being used has been identified as functionally identical to the original engine.
Engine Changes
Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle:
The engine must be the same year or newer than the vehicle.
The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy- duty truck, etc.) based on gross vehicle weight.
If the vehicle is a California certified vehicle then the engine must also be a California certified engine.
All emissions control equipment must remain on the installed engine.
After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine.
Ref a B18C in a CX.
Re: California Smog answers! *End all to all* (Spade)
Ok, so my understanding is that the JDm engin must be the eqilivant of the american counterpart right? so could i smog a 200 jdm type r moter in a 2000 cx?
Re: California Smog answers! *End all to all* (Trooper)
Yup. You will need a USDM ECU and Exhaust manifold though.
The JDM 4-1 is not legal but, you will have no problems what so ever selling it and then all you have to do is purchase a aftermarket header with a little extra cash on top of the money you made selling the JDM 4-1.
Re: California Smog answers! *End all to all* (EKology)
Nice write up!! This should clear up the confusion with legalizing a JDM motor swap in CA.
Re: California Smog answers! *End all to all* (B_Cruz)
wish me luck, I am reffing on Friday
2nd visit if you fix everything they told you, you get a sticker Well, for 8 bux.
Thanks again to Spade who put an end to all this "JDM motors are illegal in CA" BS. Good luck to all JDM owners.
Re: California Smog answers! *End all to all* (93SSPHatch)
Wait I'm confused would this only apply to same year only because i have and older verison motor in my 98 hatch can I still pass if I fix what needs to be fixed when I need to see the Ref
Re: California Smog answers! *End all to all* (wid326)
If you have an engine that is older than your vehicle you must sell it and get one that is same year or newer. There is no way for you to pass even if you upgrade all emissions equipment to your chasis or newer.
k cool thx for the info
Heres my dilemma k. i got a jdm b20 long block runnig a ls tranny and a ls head i bought from a friend. I wanna get the BAR sticker imma drop the motor in less than 2 weeks(car in shop) right now the motor is stock and imma add all the necessary smog equiment when i do the drop do u think i will pass. i have a 97 cx and the motor is a 98/99 b20.
any help will greatly be appreciated thxs.
Re: California Smog answers! *End all to all* (CTRKID)
Trannies don't matter.
The LS head should be fine since it is a duplicate of the B20.
I don't foresee any problems. Just make sure you have all the vaccum lines hooked up.
Bump for Spade, another informative post, wow, do you ever sleep? LOL, anyway, keep up the good research!
[QUOTEJapanese Replacement Engines
Used engines imported from Japan can be used as replacement engines as long as the engine being used has been identified as functionally identical to the original engine.[/QUOTE]
So how can a civic have a JDM B series engine if this quote says that it has to be functionally identical to the original engine....
the way i understand this is that a 95 del sol DOHC VTEC can get a 95+ JDM engine to replace their blown engine....
not a 95 civic with a D series being replaced with a 95+ JDM B series???
I think that replacing a D with a B is not functionally identical....
The only way that I can see that they are functionally identical is that they are engines that have cams, pistons, and they operate like any other engine....
is this what it is saying or what??
"Heads
Replacement heads must be identical to the original part. Head swaps from different years, engines or makes are illegal. Aftermarket heads or valve train components that are not made to the same specifications as the original parts require an Executive Order to be legal for street use."
and second
Re: California Smog answers! *End all to all* (degooser)
just making sure.....
you know how those things are written...they sometimes dont make any sense....
I need some hope..for getting a JDM engine....
know what I mean..
they are cheaper, and seem to be a lot more around than the US ones..
know what I mean..
know what I mean..
know what I mean..
Good luck. If you have any further questions, call a ref yourself. They are more then happy to answer all of your questions and myths about JDM engines.
