minime wiring???
Old Oct 19, 2005 | 02:12 PM
efhatchbackracer's Avatar
Default minime wiring???
i am currently making a minime swap in my ef hatchback and i am totally lost on what i need as well as what i need to do to wire vtec into my ECU. i've never wired anything on a motor, so if anyone can help please do. thanks
Old Oct 19, 2005 | 02:21 PM
dohdoh420's Avatar
Default Re: minime wiring??? (efhatchbackracer)
I know I'm not really the one who has the right to say this, but do a search. also what is your car, SI, DX?
Old Oct 20, 2005 | 09:36 PM
my car is a dx.
Old Oct 20, 2005 | 10:03 PM
c0nspire's Avatar
you need a conversion harness for the ecu (odb0 to obd1) the harness has the 6 extra leads you need from the engine bay
I made my own harness buti heard the ones from rywire are very good, check them out
after that you pretty much just run the wires from the engine bay thru a hole to your ecu.
the wires are as follows:
2 wires from the odb1 distributor
1 wire from the vtec solenoid
1 wire from the odb1 EACV
1 wire from the vtec pressure switch
and not sure if u need this, but i did.
the org/blk lead from a 4wire O2 sensor
Old Oct 21, 2005 | 12:18 AM
Rywire's Avatar
Default Re: (c0nspire)
Just give me a call at rywire, ill tell you all thats needed, If you dont want to buy, thats cool... Ill still let ya know what you need.
Ryan
TeamRPM_ZC
Jul 14, 2008 08:36 AM
slow_cx
Aug 22, 2007 11:11 AM
free99
Jun 21, 2007 07:45 AM
Bseriesy0
Sep 21, 2004 09:43 AM
Azntwins
Mar 8, 2004 12:08 PM
