what year d16y8 intake manifold is this?
Old Oct 19, 2005 | 01:59 PM
Bense's Avatar
Default what year d16y8 intake manifold is this?
and how do you know?
Old Oct 19, 2005 | 02:06 PM
.Beaver's Avatar
Bloody Beaver
Default Re: what year d16y8 intake manifold is this? (Gordon Liddy)
99-00 it has the air holes or w/e they're called
Old Oct 19, 2005 | 02:08 PM
Bense's Avatar
Default Re: what year d16y8 intake manifold is this? (Leeroy)
are those the tiny holes above the injectors?
Old Oct 19, 2005 | 02:13 PM
.Beaver's Avatar
Bloody Beaver
yup air injection I think its called
Old Oct 19, 2005 | 02:25 PM
Bense's Avatar
i'm confused how this works, cause i'm holding it up to my 1998 y5 head and the holes don't match up to anything, yet i'll supposedly get a huge vaccuum leak if i use this intake manifold without plugging the holes.
are these like tiny intake ports for the injectors or something?
Old Oct 19, 2005 | 02:27 PM
sicones's Avatar
if your using that intake mani on a 96-98 head you have to jb weld the four little holes above each injector then sand it down to make it smooth, the one in the center does not matter
Old Oct 19, 2005 | 02:34 PM
EK k kay's Avatar
Default Re: what year d16y8 intake manifold is this? (sicones)
JB weld those 4 tiny holes shut as well as the middle larger one or cap off the nipple at the top. Even though they don't seem to line up with anything, you will have a vacuum leak if you don't.
Old Oct 19, 2005 | 02:43 PM
Bense's Avatar
Default Re: what year d16y8 intake manifold is this? (EK k kay)
if i were to get a 96-98 intake manifold gasket, would that block them off?
Old Oct 19, 2005 | 02:50 PM
coquitlamEG's Avatar
Never tried it, but makes sense to me?
Old Oct 19, 2005 | 03:15 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gordon Liddy &raquo;</TD></TR><TR><TD CLASS="quote">if i were to get a 96-98 intake manifold gasket, would that block them off?</TD></TR></TABLE>
It might, but since you don't have it installed, might as well shut the holes up to be on the safe side.
Old Oct 19, 2005 | 04:54 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">It might, but since you don't have it installed, might as well shut the holes up to be on the safe side.</TD></TR></TABLE>
yeah, i'm wondering if i could use some allen headless screws with loctite to plug them off, if not, time to bust out the aluminum mig welder at work
tamadrumr88
Jun 19, 2014 01:16 PM
immajackuup
Feb 27, 2008 06:35 AM
civicdude00
Aug 4, 2007 09:35 AM
AGENT 99
Aug 30, 2006 02:25 PM
Ayeso
Nov 15, 2005 09:38 PM
