Intake Manifold Help 96-98/99-00
Help y0
On a 00 d16y8 engine, a 96-98 intake manifold will work as long as I use a 96-98 intake manifold gasket, correct?
Before you answer, make sure you're aware that the 99-00 intake manifold were changed for emissions reasons.
This (notice gaskets people) is a 96-98 style intake manifold.
This, is a 99-00 style intake manifold.
you will prolly throw a CEL, and have a leak. the 99-00's have AIR Injection ports in the manifold, and if you use a 96-98 gasket, it wont accomodate for those ports. like i said, it will probably have a leak and will probably throw a CEL, but you CAN throw a 99-00 IM on a 96-98 head, if you use a 99-00 gasket and plug the holes in the IM.
Re: (Tru)
Yes it will work. On a 99-00 d16y8 intake manifold there is a large vacuum nipple on top the the flange and since you are using a 00 d16y8 motor, make sure you cap off the other end of that vacuum hose wherever it leads to.
Re: (AGENT 99)
I don't know, but if you search through the diagrams for the vacuum hoses etc I'm sure it will show you where it goes. I think it goes somewhere near the thermostat housing.
Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">I don't know, but if you search through the diagrams for the vacuum hoses etc I'm sure it will show you where it goes. I think it goes somewhere near the thermostat housing.</TD></TR></TABLE>
odd considering there the same engine.. but w/e
youre going to have a leak. and your AIR injection wont work, so i dont know about emmissions. search for it on D-Series.org....i had the same problem, but 99-00 head on a 96-98 motor. you have to seal lthe holes or itll leak.
immajackuup
02-27-2008 06:35 AM
fastcrxsi90
12-24-2002 03:51 PM
fastcrxsi90
12-24-2002 10:03 AM
