what year d16y8 intake manifold is this?
Go Tigers!
Re: what year d16y8 intake manifold is this? (Leeroy)
i'm confused how this works, cause i'm holding it up to my 1998 y5 head and the holes don't match up to anything, yet i'll supposedly get a huge vaccuum leak if i use this intake manifold without plugging the holes.
are these like tiny intake ports for the injectors or something?
Re: what year d16y8 intake manifold is this? (Gordon Liddy)
if your using that intake mani on a 96-98 head you have to jb weld the four little holes above each injector then sand it down to make it smooth, the one in the center does not matter
Re: what year d16y8 intake manifold is this? (sicones)
JB weld those 4 tiny holes shut as well as the middle larger one or cap off the nipple at the top. Even though they don't seem to line up with anything, you will have a vacuum leak if you don't.
Go Tigers!
Re: what year d16y8 intake manifold is this? (EK k kay)
if i were to get a 96-98 intake manifold gasket, would that block them off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gordon Liddy »</TD></TR><TR><TD CLASS="quote">if i were to get a 96-98 intake manifold gasket, would that block them off?</TD></TR></TABLE>
It might, but since you don't have it installed, might as well shut the holes up to be on the safe side.
Go Tigers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">It might, but since you don't have it installed, might as well shut the holes up to be on the safe side.</TD></TR></TABLE>
yeah, i'm wondering if i could use some allen headless screws with loctite to plug them off, if not, time to bust out the aluminum mig welder at work
immajackuup
02-27-2008 06:35 AM
civicdude00
08-04-2007 09:35 AM
Ayeso
11-15-2005 09:38 PM
