Question on how to O-Ring exhaust flange
Old Oct 19, 2005 | 12:36 PM
AP-Signworks1's Avatar
Default Question on how to O-Ring exhaust flange
A friend has asked me to make some flanges for him for a custom project. Not a problem since we run waterjets, but the flanges he needs have a groove in them for an O Ring.
This is one of the flanges we need to make, notice the groove around the pipe for the O Ring.
Does anyone know how flange makers get that groove in there? I can probably take it to a local machine shop, but I'm wondering if that is the standard method, or if there is another way.
Old Oct 19, 2005 | 12:51 PM
tony1's Avatar
Default Re: Question on how to O-Ring exhaust flange (AP-Signworks1)
I'm sure they're all machined in there. I know i've had some done and that's how they were done. Another option is to make a gasket or use the orange high temp gasket maker to seal it.
Old Oct 19, 2005 | 01:32 PM
Default Re: Question on how to O-Ring exhaust flange (tony1)
Thanks, that's what I thought. I'll see if I can convince him of the gasket, he was against it because he thought it would leak.
Old Oct 19, 2005 | 03:00 PM
Tony the Tiger's Avatar
If the pipes aren't before a turbo (like the up-pipe on the WRX's, etc...) and doesn't have to hold tremendous amounts of pressure, the gasket maker stuff will work out no problem.
I have a couple of flanges that are pre-turbo on one of my cars. I do have to reseal some of the exhaust connections every now and then, and I am actually thinking of going with the O-ringing.
Old Oct 19, 2005 | 03:19 PM
Ekasey's Avatar
used honda bond on cylinder head flanges without a problem!
Old Oct 19, 2005 | 05:09 PM
project dc2's Avatar
Default Re: Question on how to O-Ring exhaust flange (Casey@Burns)
stick it in a lathe and spin it. then you can ring it
Old Oct 20, 2005 | 04:47 AM
2kjettaguy's Avatar
Default Re: Question on how to O-Ring exhaust flange (project dc2)
What kind of o-rings are you guys using that can stand up to the heat?
jBj
Nov 18, 2005 03:31 PM
Johnny_Rocket
Jun 30, 2005 06:10 PM
MrCivic98
Apr 13, 2004 03:16 PM
gdrum
Jan 9, 2004 10:40 AM
Bigstothel
May 23, 2002 05:54 AM
