Manley Rods
Old Oct 19, 2005 | 06:47 AM
Turbocivic94's Avatar
Default Manley Rods
I just purchased manley rods and they weight only 380 grams per rod. These rods will be going in high hp turbo motor. To me they seem like na rods.
Are these rods safe in turbo motor?
Old Oct 19, 2005 | 06:53 AM
G
sh!t happens.
Default Re: Manley Rods (Turbocivic94)
I bought the same set of rods for my motor. I purshased them from earl. They will do good.
Old Oct 19, 2005 | 07:46 AM
Default Re: Manley Rods (G"UNIT)
Thanks bro
I want your fuel system but cant afford it right now.
Old Oct 19, 2005 | 09:06 AM
SlowReaction's Avatar
My manleys are over 500 grams each
Old Oct 19, 2005 | 11:06 AM
earl's Avatar
Default Re: Manley Rods (SlowReaction)
Depending on the rod, All motor manleys should be close to 500g whereas the turbos are about 560. The 380 weight you are referring to is just the weight of the big end only.
Old Oct 19, 2005 | 11:10 AM
G
sh!t happens.
Default Re: Manley Rods (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Depending on the rod, All motor manleys should be close to 500g whereas the turbos are about 560. The 380 weight you are referring to is just the weight of the big end only.</TD></TR></TABLE>
Well how would the all motor rods do with boost since they are lighter?
Old Oct 19, 2005 | 11:45 AM
earl's Avatar
In the case of Manleys, they seem to have the same strength whether all motor or turbo. The extra weight is just for the thin area in the center of the rod. Turbo rods just slightly thicker in that area.
Manley AM weigh 495g
Pauter 520g
Manley TT 560g
Old Oct 19, 2005 | 02:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">In the case of Manleys, they seem to have the same strength whether all motor or turbo. The extra weight is just for the thin area in the center of the rod. Turbo rods just slightly thicker in that area.
Pauter 520g
Manley TT 560g</TD></TR></TABLE>
Thanks for info earl
I didnt want to put these in my motor and worry about them
Then these are 498g
Old Oct 19, 2005 | 04:08 PM
nfn15037's Avatar
From my Turbo-Tuff B18C rods. (thanks Earl)
Old Oct 19, 2005 | 04:40 PM
nota-eg's Avatar
Default Re: Manley Rods (nfn15037)
How do these compare to eagle in price and stregnth?
Old Oct 19, 2005 | 04:55 PM
nfn15037's Avatar
Default Re: Manley Rods (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">How do these compare to eagle in price and stregnth?</TD></TR></TABLE>
They don't.....
Old Oct 19, 2005 | 05:03 PM
nota-eg's Avatar
Not as strong? Not as expensive? Stronger and more expensive?
Old Oct 19, 2005 | 05:06 PM
nfn15037's Avatar
They are stronger and more expensive. In fact, I can't think of a better rod in my opinion.
Old Oct 19, 2005 | 05:07 PM
k24em2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">Stronger and more expensive</TD></TR></TABLE>
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote"> Stronger and more expensive?</TD></TR></TABLE>
Old Oct 19, 2005 | 05:08 PM
Default Re: Manley Rods (NJIN BUILDR)
OK that was scary.....
Old Oct 19, 2005 | 05:18 PM
null.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">They are stronger and more expensive. In fact, I can't think of a better rod in my opinion.</TD></TR></TABLE>
pauter
Old Oct 19, 2005 | 05:20 PM
nfn15037's Avatar
Default Re: Manley Rods (eg6junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6junkie &raquo;</TD></TR><TR><TD CLASS="quote">pauter</TD></TR></TABLE>
Says who? More money doesn't equal better.....
Old Oct 19, 2005 | 05:38 PM
m R g S r's Avatar
thats why someone should buy my b16a...it has these rods!!!! buy it someone!!!
Old Oct 19, 2005 | 06:03 PM
Importordomestic's Avatar
Default Re: Manley Rods (m R g S r)
When i talked to Sean at ERL the other day he told me that they are switching from crower rodsto manley, he said they seem to be better than other brands.
you can always take a professionals opinion to heart.
Old Oct 19, 2005 | 08:24 PM
Default Re: Manley Rods (Importordomestic)
Manleys got my vote. These rods will be seeing a lot of boost.
Old Oct 19, 2005 | 09:10 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">Says who? More money doesn't equal better.....</TD></TR></TABLE>In Pauters case it does
Old Oct 19, 2005 | 09:20 PM
LSR-Abuser's Avatar
i am going to buy manley rods,they make a great rod for the price.
And earl I am going to buy a set for you i had to use the money i had saved but almost got it saved back up, will pm you
silverskateEF9
31
Oct 6, 2007 07:13 PM
h22silvia
Feb 1, 2007 04:49 PM
racerboyb18c1
28
Oct 19, 2005 03:15 PM
Pfieff
Dec 29, 2003 09:09 AM
johnzm
28
Oct 5, 2003 06:39 AM
