chip ecu and gm3bar map sensor
Old Oct 19, 2005 | 06:21 AM
Hulk22's Avatar
Default chip ecu and gm3bar map sensor
if you have a chip ecu for turbo to run on the stock map sensor which 11psi. would i need the chip reprogram to read the 3bar to run more boost or is it just setting a switch in the ecu. thanks
Old Oct 19, 2005 | 06:22 AM
The Weather Man's Avatar
Stop being cheap - get a hondata s300 or something. You must want to mess up your motor.
Old Oct 19, 2005 | 06:29 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (TheKingPin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin &raquo;</TD></TR><TR><TD CLASS="quote">Stop being cheap - get a hondata s300 or something. You must want to mess up your motor. </TD></TR></TABLE>
i would have to agree. get it tuned correctly with the correct map for the 3 bar.
Old Oct 19, 2005 | 06:36 PM
Hulk22's Avatar
Default Re: (boostedcivicsir)
s200 comming in dec.
Old Oct 19, 2005 | 06:44 PM
Mr. Badwrench
Default Re: (Hulk22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulk22 &raquo;</TD></TR><TR><TD CLASS="quote">s200 comming in dec. </TD></TR></TABLE>
problem solved.
dc4teg95
Mar 9, 2008 11:59 PM
teg92
19
Jan 20, 2005 01:09 PM
int3gragsr
Oct 7, 2004 10:27 PM
DubyaAye
Apr 28, 2004 10:22 PM
vtec.dc2
Feb 12, 2004 04:39 PM
