Purpose of heat shield on cat. converter?
if you drive over tall, dry grass you could possibly start a fire
Some people take it off if it rattles. It's a known problem with Integras. I say if you're not having a problem, just leave it. If it's not broke, don't fix it.
so that's what that rattling noise is comming from.... Is there any way to stop the rattling without removing the cat? and if you take out the heatshield does the shifter get really hot? or just warm??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC »</TD></TR><TR><TD CLASS="quote">You can go to home depot or lowes and use a metal band that ties around pipes for your cat. I used this to tie the heatshield down. no rattling or problems since.
same here for me...
</TD></TR></TABLE>same here for me...
Guest
Posts: n/a
easy way to get rid of rattling heat shield and hot cat, and increase performance: take off the cat and remove the heat shield. take a piece of pipe and jam it into the cat (NOT THE SIDE!). get all that restrictive crap out of there and let you exhaust breath! dont forget to put the cat back on (duh). i live in ohio, so anyone here could care less if its smog legal or not
AWDSOME
Dec 28, 2001 05:26 PM
