COMPRESSION TEST ON JDM B18C ITR
I did my test and got these numbers....and this is without the butterfly valve at wide open throtle
Cylinder 1- 215
Cylinder 2- 200
Cylinder 3- 220
Cylinder 4- 205
Are these o.k. cause they're all within 10% of eachother?
Would these be in the "normal" 230-240 range with WOT?
let me know guys...thanks
Cylinder 1- 215
Cylinder 2- 200
Cylinder 3- 220
Cylinder 4- 205
They look OK, but why don't you do the test right and let us know those numbers.
1. pull ECU fuse
2. Hold WOT
3. Crank a consistent number of times for each cylinder.
Do the test when the engine is warm.
1. pull ECU fuse
2. Hold WOT
dajman94
12
Oct 18, 2005 12:25 PM
