92-95 cx hatch brake upgrade???????????
Old Oct 17, 2005 | 07:04 AM
crush's Avatar
Default 92-95 cx hatch brake upgrade???????????
i have 95 gsr disc converion fron and back. ss brake lines, integra porpotioing vavle off an ls and a booster off an si hatch buth te master cylinder is still the 13/16 my braking seems week but better than stock pedal is not as firm as i need it. I need to know what booster and master cylinder fits on the cx hatch and will itmake a huge difference if not just what mc will fit straight in.
Old Oct 17, 2005 | 08:25 AM
aspec101's Avatar
Default Re: 92-95 cx hatch brake upgrade??????????? (crush)
go with the integra MC and pop valve.
Old Oct 17, 2005 | 06:04 PM
jpb105079's Avatar
you can use the master cylinder off a 91 civic ex it a 15/16 and you wouldn't have to replace your brake booster.
Old Oct 17, 2005 | 06:11 PM
EL Vap133's Avatar
If I were you I'd use the 94-00 Integra RS master cylinder and brake booster.
Old Oct 17, 2005 | 06:16 PM
taney's Avatar
Default Re: 92-95 cx hatch brake upgrade??????????? (EL Vap133)
listen to el vap .. but make sure you get the 40/40 non-abs prop valve .. it helps THAT much more!
Old Oct 17, 2005 | 07:37 PM
socaleg6's Avatar
I'm doing the same conversion on a 92 Civic DX. Can you use the master cylinder / brake booster from a 96 GSR and the proportion valve from a RS?
Side note: the brake lines going to the master cylinder are not in the same locations - Civic DX vs. Integra... Whats the solution?
Thanks
Old Oct 17, 2005 | 07:42 PM
93civicsedan's Avatar
Default Re: (socaleg6)
you can use any 94-01 integra brake booster as long as its non-abs. the master cylinder should also be non-abs. I got mine off a 95 RS. use a 4040 prop valve.
Old Oct 19, 2005 | 02:59 PM
socaleg6's Avatar
Thanks "93civicsedan"
DO you know if the existing hydrolic lines will work? Do I have to bend or replace lines or is it a direct bolt on?
Thanks again!
Old Oct 19, 2005 | 03:14 PM
sockvtec's Avatar
if you get the integra bb/and mc make sure you get the integra ss lines or whatever or you will have to modify your stock ones....also the 40/40 prop valve you can get from any civic or teg with disk on all 4 corners
Old Oct 20, 2005 | 07:20 PM
skoolz4loserz's Avatar
Chev
Sep 22, 2017 09:52 PM
StreetRacin101
Apr 15, 2009 04:13 AM
CivicVX94
16
Oct 17, 2007 07:40 PM
B HATCH
11
Apr 15, 2004 05:07 PM
