How to remove alternator in Civic with B16?
Old Oct 16, 2005 | 11:55 PM
Nick7's Avatar
Default How to remove alternator in Civic with B16?
My alternator bearing are going south.
First it was a light whistle that one could occasionally hear, but now it's getting much worse, so it's time to replace those bearings.
However, it seems a bit hard to pull out alternator without moving engine, etc.
Car is '97 Civic (6th gen) with B16A2 swap and it's pretty cramped there where alternator is.
Can anyone tell me what do I need to remove, and what's the easiest way to pull alternator out?
Tnx.
Old Oct 17, 2005 | 02:10 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How to remove alternator in Civic with B16? (Nick7)
I believe it would be easier for you to remove it from underneatht the car. Unless you feel like removing your intake manifold.
Old Oct 17, 2005 | 04:37 AM
Nick7's Avatar
Default Re: How to remove alternator in Civic with B16? (JDM_Ej)
Well, I've been searching... so it seems there are few options:
1) Remove left axle pull it down
2) Remove shielding from dirt on left side arround wheel, an pull it through there
3) Unbolt brake cylinder from brake booster, and pull it through that side
Seems like nr. 3. will be the winner here... as seems like least work
Old Oct 17, 2005 | 06:22 AM
drdisco69's Avatar
https://honda-tech.com/zerothread?id=1401131
You've never pulled a brake booster out of a car have you? Pain in the immortal ***...
Old Oct 17, 2005 | 06:38 AM
CRX Toad's Avatar
Default Re: How to remove alternator in Civic with B16? (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">
You've never pulled a brake booster out of a car have you? Pain in the immortal ***...</TD></TR></TABLE>
Yup...had to drop 3 of my 4 mounts for just a little D-series to get booster and MC in there.
Old Oct 17, 2005 | 08:09 AM
jdmitr's Avatar
Default Re: How to remove alternator in Civic with B16? (CRX Toad)
Do some looking around...I have never had to take apart anything major to get it out!
Old Oct 17, 2005 | 10:08 AM
gents97civ's Avatar
you dont have to pull the booster. I have a b18c in a 97ex. I just took of some little things like vaccum lines and I took off the whole alt mount to get mine out. Much easier than the options you stated.
Old Oct 18, 2005 | 01:53 AM
Nick7's Avatar
Tnx for info.
This weeked I'll try to pull it out.
It's nice to know possible options if one way fails
Old Oct 18, 2005 | 04:33 AM
gents97civ's Avatar
Go out and take a look at it, you should be able to do it like I said. I think I took off a little metal bracket on the driver side, the vaccum hose off the mani, and the whole bracket for the alt and that was it.
Old Oct 24, 2005 | 05:58 PM
Sottilde's Avatar
Default Re: (gents97civ)
I have the same problems - bearings are going out. I have two options, I figure - pull it out and fix the bearings (is that possible?) or order a used one, as the new ones are too expensive. Anyone know of any way to fix the thing without ordering a new one?
Old Oct 24, 2005 | 11:14 PM
Nick7's Avatar
Default Re: (Sottilde)
There are shops which can replace bearing.. they just dismantle alternator, replace bearing and put it together.
This is also good time to check if alternator's brushes are good too.
Old Oct 25, 2005 | 10:06 AM
Sottilde's Avatar
Default Re: (Nick7)
Hrmm. Do you know what kind of shop might be able to do that, or how I may do it myself?
Old Oct 25, 2005 | 11:17 PM
Nick7's Avatar
Well, I knew people who can do that here (in Croatia), so I'm not sure in US who does this stuff.
But, try asking shops that do bearings&stuff, they might know.
ef9robert
20
Sep 25, 2006 12:01 PM
Jap_Spec_Imports
Jun 27, 2006 10:30 AM
Synthead
Jul 31, 2005 08:55 PM
90 Si Hatch
Sep 10, 2004 03:48 AM
Shft@9GSR
Nov 23, 2002 08:05 PM
