Swappinq a 91 LS B18 into my 93 Hatch
Old Oct 16, 2005 | 10:20 PM
jdm_eqsi's Avatar
Default Swappinq a 91 LS B18 into my 93 Hatch
ok. I have the complete motor and tranny and ECU. what else is needed to complete this swap?
Old Oct 16, 2005 | 10:44 PM
spreng87's Avatar
Default Re: Swappinq a 91 LS B18 into my 93 Hatch (jdm_eqsi)
since it's a 91 b18a you are gonna need an 92+ distributor because your EG is OBD1 and your 91 b18a is a Pre OBD or OBD0 you can use your EG engine harness if you change a couple of wires like the dizzy and i'm not sure what else... I have an LS in my EG but it was a b1.... basically a direct bolt on
You are gonna need a Bseries rear bracket from a 94-01 integra. and you are gonna need to repin your old o2 sensor to work with your ECU. you are using a OBD1 ECU correct? 94-01 shift linkage. Hopefully it's not a cable tranny or else you are gonna need a new tranny mount (IE HAsport) because EGs are hydro.... someone cover the rest because i can't think of any
Old Oct 16, 2005 | 10:57 PM
TsukubaDreams's Avatar
Look at the pasties on the top of the page..... so much info in there and there is a search button too... works a lot better than just asking cause ppl just skip over it cause it gets asked so much..... good luck with the swap though.
Old Oct 16, 2005 | 11:23 PM
jdmpremonition's Avatar
Default Re: Swappinq a 91 LS B18 into my 93 Hatch (spreng87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spreng87 &raquo;</TD></TR><TR><TD CLASS="quote">since it's a 91 b18a you are gonna need an 92+ distributor because your EG is OBD1 and your 91 b18a is a Pre OBD or OBD0 you can use your EG engine harness if you change a couple of wires like the dizzy and i'm not sure what else... I have an LS in my EG but it was a b1.... basically a direct bolt on
You are gonna need a Bseries rear bracket from a 94-01 integra. and you are gonna need to repin your old o2 sensor to work with your ECU. you are using a OBD1 ECU correct? 94-01 shift linkage. Hopefully it's not a cable tranny or else you are gonna need a new tranny mount (IE HAsport) because EGs are hydro.... someone cover the rest because i can't think of any</TD></TR></TABLE>
so what all is needed to do the b18b1 swap into a 93 eg?
Old Oct 19, 2005 | 11:25 PM
DB1_559's Avatar
in my 93 with the same a1 axels i use is 92-93 integra left side and on the rite i used 89 integra and all that other obdo crap dont know hope that will help
Old Oct 20, 2005 | 12:26 AM
hatchi's Avatar
convert engine to obd1 specs. obd1 ecu, intake manifold, injectors, alternator, dist. mounts, block mount.
reuse your stock harness
Old Oct 22, 2005 | 01:13 PM
jdm_eqsi's Avatar
ok what about Axles? what axles can I use. *Askinq Hatchi* he seems to know.
BillyBong
Dec 22, 2008 01:43 PM
jdm_eqsi
Oct 22, 2005 01:25 PM
ilsimsli
Jan 22, 2005 01:01 AM
slammedcivicsi
Aug 4, 2003 04:09 AM
IhateMy93BlackHatch
Jan 12, 2003 06:05 PM
