Swappinq a 91 LS B18 into my 93 Hatch
Re: Swappinq a 91 LS B18 into my 93 Hatch (jdm_eqsi)
since it's a 91 b18a you are gonna need an 92+ distributor because your EG is OBD1 and your 91 b18a is a Pre OBD or OBD0 you can use your EG engine harness if you change a couple of wires like the dizzy and i'm not sure what else... I have an LS in my EG but it was a b1.... basically a direct bolt on
You are gonna need a Bseries rear bracket from a 94-01 integra. and you are gonna need to repin your old o2 sensor to work with your ECU. you are using a OBD1 ECU correct? 94-01 shift linkage. Hopefully it's not a cable tranny or else you are gonna need a new tranny mount (IE HAsport) because EGs are hydro.... someone cover the rest because i can't think of any
Look at the pasties on the top of the page..... so much info in there and there is a search button too... works a lot better than just asking cause ppl just skip over it cause it gets asked so much..... good luck with the swap though.
Re: Swappinq a 91 LS B18 into my 93 Hatch (spreng87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spreng87 »</TD></TR><TR><TD CLASS="quote">since it's a 91 b18a you are gonna need an 92+ distributor because your EG is OBD1 and your 91 b18a is a Pre OBD or OBD0 you can use your EG engine harness if you change a couple of wires like the dizzy and i'm not sure what else... I have an LS in my EG but it was a b1.... basically a direct bolt on
You are gonna need a Bseries rear bracket from a 94-01 integra. and you are gonna need to repin your old o2 sensor to work with your ECU. you are using a OBD1 ECU correct? 94-01 shift linkage. Hopefully it's not a cable tranny or else you are gonna need a new tranny mount (IE HAsport) because EGs are hydro.... someone cover the rest because i can't think of any</TD></TR></TABLE>
so what all is needed to do the b18b1 swap into a 93 eg?
in my 93 with the same a1 axels i use is 92-93 integra left side and on the rite i used 89 integra and all that other obdo crap dont know hope that will help
jdm_eqsi
10-22-2005 01:25 PM
IhateMy93BlackHatch
01-12-2003 06:05 PM
