Iac block off?
I think you can remove the iac by blocking off and plugging the hose lines. will that work? and 2nd if it will where can i get the plates. i tries to search on ebay an no luck. i also tries google. Thanks for the hlep. i trying to free up some space there for my nitrous set up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">for cold weather right?</TD></TR></TABLE>
Well, for the car to idle properly.
I had mine blocked off for a while when i had a bad iavc . It adjusted the idle with the idle screw, but im in fl so cold starts arnt usually a problem. I left it plugged in with a plate over the ports.
del_parker
Jul 22, 2003 06:53 PM
