dual headers?
Old Oct 16, 2005 | 01:57 PM
delguy's Avatar
Default dual headers?
what do you guys think if you had 2 of the exhaust header pieces come into one pipe and thesame on the other side(yes im talking about a 4 cyl.)for a true dual exhaust from the headers bask,just an idea.
Old Oct 16, 2005 | 02:47 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: dual headers? (delguy)
this one is almost as good as your other posts
Old Oct 16, 2005 | 03:15 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguy &raquo;</TD></TR><TR><TD CLASS="quote">what do you guys think if you had 2 of the exhaust header pieces come into one pipe and thesame on the other side(yes im talking about a 4 cyl.)for a true dual exhaust from the headers bask,just an idea.</TD></TR></TABLE>
...those salmon eggs must be getting to your head
Modified by Autoworks at 12:27 AM 10/17/2005
Old Oct 16, 2005 | 05:29 PM
91civicDXdude's Avatar
why not just go the distance and do the quad exhaust!
if not that, maybe some diesel stacks or side pipes like old muscle cars!
Old Oct 16, 2005 | 05:32 PM
delguy's Avatar
Default Re: (91civicDXdude)
like i said it was just an idea,you guys complain and nag about anything.
why wouldnt it work?
Old Oct 16, 2005 | 05:37 PM
NJIN BUILDR's Avatar
Default Re: (delguy)
It would work,just not as well as a four into one or a four into two into one.You would give up half of the scavenging pulses.
Glenn
Old Oct 16, 2005 | 05:44 PM
delguy's Avatar
Default Re: (NJIN BUILDR)
thanks for real answer
Old Oct 16, 2005 | 06:26 PM
SkankyEJ7's Avatar
Default Re: dual headers? (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by Autoworks at 12:27 AM 10/17/2005</TD></TR></TABLE>
its either that or the butt s3x
Old Oct 16, 2005 | 07:54 PM
JdmB16Eg6's Avatar
65.115.123.226
Default Re: dual headers? (98ekhx)
i think your back pressure would be messed up like this ?
Old Oct 16, 2005 | 09:01 PM
flight50's Avatar
Default Re: dual headers? (JdmB16Eg6)
needing backpressure is a myth. you don't need it.
Old Oct 16, 2005 | 10:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmB16Eg6 &raquo;</TD></TR><TR><TD CLASS="quote">i think your back pressure would be messed up like this ?</TD></TR></TABLE>
thats why when you run your 4 individual pipe "quad header" you make each one of them out of 1/4" tubing, so you'll have efficient back pressure
Old Oct 17, 2005 | 02:42 AM
delguy's Avatar
Default Re: dual headers? (91civicDXdude)
ok i beleive ths same as flight50 that you dont need backpressure, so explain and give me examples of why you need back pressure.
Old Oct 17, 2005 | 06:05 AM
Autoworks's Avatar
You do need a certain amount of backpressure on a driveable street car
Old Oct 17, 2005 | 06:36 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">You do need a certain amount of backpressure on a driveable street car</TD></TR></TABLE>
Nope.
Old Oct 17, 2005 | 12:53 PM
just to clarify, i was being sarcastic. the whole 'backpressure" issue has been discussed to death, so if you really still belive that your engine needs backpressure, please do a search or google exhaust gas velocity vs. backpressure
Old Oct 17, 2005 | 12:57 PM
delguy's Avatar
so there would be no issues and it would be okay to do this exhaust setup?
Old Oct 17, 2005 | 04:20 PM
lohatch's Avatar
so there would be no issues and it would be okay to do this exhaust setup?</TD></TR></TABLE>
not likely. if it yeilded gains there would be people running simular setups. there are reasons for the pairing of the primaries. some light reading for yah compliments of burns stainless....http://www.burnsstainless.com/....html
Old Oct 17, 2005 | 04:25 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (lohatch)
I quit at life.
Old Oct 17, 2005 | 04:36 PM
machine4321's Avatar
back pressure and velocity are 2 different things ,
you DO NOT need back pressure , velocity on the other hand is a good thinkg to have . back pressure is a restriction and doesnt allow for the best flow . a properly design header with the right size of piping will not only be efficient but will have good velocity for good scavenging .
if im wrong please correct me
Old Oct 17, 2005 | 06:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">It would work,just not as well as a four into one or a four into two into one.You would give up half of the scavenging pulses.
Glenn</TD></TR></TABLE>
I think I used the key word,yup I'm sure I did.It had something to due with pulling the spent gasses out of the port and helping pull the air/fuel in.Yup that was the word.
Glenn
5SpeedEJ6
21
Jul 18, 2014 12:46 PM
KamikazeS2K
19
May 27, 2006 12:23 PM
blackriceman
Apr 24, 2004 01:42 PM
01nhbgsr
Jul 9, 2003 11:53 AM
mrcrimane
Feb 26, 2003 12:29 PM
