short shifter
any reccomendations? some claim to change the pivot angle or something instead of just cutting down the handle. ive been trying to research this topic but im confused on what to buy
I've installed a short shifter one week ago... and it did make a good difference.
Now, I am going to cut a piece of the handle, and weld it back shorten........ that should make it "shorter short shifter"...
Anyway... ...the little piece that gives you short shifts is always nice... ...don't fall for those 50% to 60% less throw..... ....because they only give you 25% to 40% less throw... depending on the shape of the item!
for the accords/preludes with cable linkage all they do is move the mounting location of the shiftcable higher making a slightly shorter throw...i believe the pivot angles would only apply to cars equipped with a rod type linkage such as civic/integra...
Casmello, so you are still alive? Great news, I've been pm'ing you about leanracing's contact info. They don't reply back to emails, so is there any other way I can get in touch with them?
Thanks
Thanks
i have the PSpec tuning short throw shifter....its awesome
it shorten the actual length of the throw but changing the monitng points of the cables, and changes the angles by changing the shapr and length of the actual shifter arm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">i have the PSpec tuning short throw shifter....its awesome
Yeah, one of these days they will make it for the 6th gen too.
it shorten the actual length of the throw but changing the monitng points of the cables, and changes the angles by changing the shapr and length of the actual shifter arm</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">
Yeah, one of these days they will make it for the 6th gen too.</TD></TR></TABLE>
too bad he as an 05
too bad he as an 05
AVXHATCH
Feb 27, 2003 02:26 PM
