obdIIa pinouts for h22 in ek
Old Oct 15, 2005 | 09:32 PM
I3iggy's Avatar
Default obdIIa pinouts for h22 in ek
ive got a 96 civic coupe with a obdI jdm h22 running the civic harness and a p28 (soon to be p72). i already have a conversion harness but it was a bit hacked from the person i bought the car from so im trying to put it back to the way its supposed to be. i found this (really old) post:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HX_Guy &raquo;</TD></TR><TR><TD CLASS="quote">I have made a list of what each OBDII pinout equals which OBDI pinout
OBDII Connector D
1 TPS = D11
2 ECT = D13
3 MAP = D17
4 VCC1 = D19
5 BKSW = D2
7 PHO2S = D14
8 IAT = D15
10 VCC2 = D20
11 SG2 = D22
12 SG1 = D21
13 SHO2/SG = NA
14 SHO2S = NA
16 EL = D10
OBDII Connector C
1 CKFP = NA
2 CKPP = B15
3 TDCP = B13
4 CYPP = B11
5 ACS = B5
6 STS = B9
7 SCS = D4
8 K-LINE =
10 VBU = D1
11 CKFM = NA
12 CKPM = B16
13 TDCM = B14
14 CYPM = B12
16 PSP SW = B8
7 ALTF = D9
18 VSS = B10
OBDII Connector A
1 INJ4 = A2
2 INJ3 = A5
3 INJ2 = A3
4 INJ1 = A1
5 SO2S HTC = NA
6 PO2S HTC = A6
9 LG1 = A26
10 PG1 = A23
11 IGP1 = A25
12 IACV = A9
15 PCS = A20
16 FLR = A7
17 ACC = A15
18 MIL = A13
19 ALTC = A16
20 ICM = A21
22 LG2 = B2
23 PG2 = A24
24 IGP2 = B1
27 FANC = A12
The only one I dont have a mathc for is OBDII C8.
It stands for "K-LINE" and "sends and receives scan tool signal.
Is this teh same pinout as OBDI D7 "TCD/RXD"? OBDI D7 is the only pinout I have left unaccounted for on the OBDI diagram. OBDI D7 wire goes to the "Data Link Connector"
but that leaves a bunch of wires left over! at least on the obd1 harness. so far i havent been able to find a complete pinout of an obdIIa ecu. just partials, and i even have the haynes manual! heres what i have left over on the obd1 end:
a4 vtec solenoid
a11 egr control solenoid valve
a17 iab solenoid
a18 transmission control module (dont think i need this anyways!)
d6 vtec pressure switch
d12 egr valve lift sensor
also it looks as though the guy before me bypassed the conversion harness with a few wires so color would be a good thing too :D. any help would be much appreciated! ive spent a bunch of time in the manuals and online, and it seems like nobody is posting up these conversion harnesses. the only one i think ive figured out is obdII c15 to obd1 d6 and and a8 - a4? any help would be much appreciated! i know you hybrid gods can answer this in a second! tia!
Old Oct 16, 2005 | 12:55 PM
I3iggy's Avatar
Default Re: obdIIa pinouts for h22 in ek (I3iggy)
ok, i know someone here knows this!
Old Oct 17, 2005 | 08:06 AM
PURPLETERROR aka BIGMATT's Avatar
http://technet.ff-squad.com/wiring.obd2a.htm
http://www.ff-squad.com/tech/w...8.jpg
http://www.ff-squad.com/tech/w...5.jpg
http://www.ff-squad.com/tech/w...t.zip
ranta18
Apr 25, 2007 06:57 PM
oneforce
44
Mar 30, 2005 04:37 PM
Jago
Jun 3, 2004 01:14 PM
Jago
Sep 26, 2003 03:58 PM
