Timing
Old Mar 5, 2002 | 05:31 PM
conorm's Avatar
Default Timing
Hi, I just need a bit of advice diagnosing a problem. WHat do you guys think it would mean if when I check the timing with a timing light the light flashes intermitently. Some times it will blink at a regular rate but then pause for a second. I tested the light on a different car, so it works fine, and I am sure the connections are right so what do you think could be going on?
Old Mar 5, 2002 | 10:33 PM
tinkerbell's Avatar
Default Re: Timing (conorm)
maybe something is going on, then off, then on, then off pause then on etc
...like a spark.
well: plug, lead, cap, rotor, ECU...in that order.
but it might just be that you are not doing it properly - esp. if your car runs ok (and you havent said that it doesnt)
t..
Old Mar 6, 2002 | 03:47 PM
Quick 200k Mile Motor's Avatar
Default Re: Timing
The magnetic pickup clip is reading something bad ..current in spark plug wire?
polishedturd
May 8, 2008 06:51 PM
Jmumblez2001
Nov 3, 2006 01:36 AM
iwouldHITit
Apr 25, 2003 08:37 PM
GSRaCeRbOI
Aug 9, 2002 05:19 PM
EGHatchy
Jul 24, 2002 10:33 AM
