95 lx, sea foam
Old Oct 14, 2005 | 10:37 AM
loup05's Avatar
Default 95 lx, sea foam
ok i picked up a can of sea foam at napa today. Im not sure where to put it thru though. i think some 1 said thru the main vacuum line. others say brake booster?
I need help from people that have used it. Also, i just had a tune up about 3 weeks ago new spark plugs oil change fuel filter air filter, i read somewhere that u have 2 give it another oil change after u use sea foam? im confused. can some one give me some clarification.
Old Oct 14, 2005 | 10:53 AM
raceACCORDingly's Avatar
brake booster vaccuum.
if you run it through your oil then i would change the oil.
Old Oct 14, 2005 | 10:56 AM
loup05's Avatar
Default Re: (raceACCORDingly)
WHERE IS THAT AT? IS IT THE HOSE ONTOP OF THE mASTER CYLINDER?
Old Oct 14, 2005 | 10:59 AM
loup05's Avatar
Default Re: (loup)
sorry about the caps. also i have 1/4 of gas dont know if that matters or not
Old Oct 14, 2005 | 11:10 AM
yes. you can really run it through any vaccuum
Old Oct 14, 2005 | 11:11 AM
loup05's Avatar
also is it really nessesary (speling??) to have an oil change after u use it if i only run it thru the vacuum line?
Old Oct 14, 2005 | 12:24 PM
loup05's Avatar
Default Re: (loup)
ok i put a little less than half in the vacuum valve it died 2wice then it just idled up and down i reved it a couple of times and white smke came out. im going 2 run it in the street 4 a few minutes. should i use the other half on the gas tank? and do i need 2 fill up b4 i put it in or put it in b4 i fill up
Old Oct 14, 2005 | 01:23 PM
jb.'s Avatar
jb.
Default Re: (loup)
you need to add it to a full tank of gas
Old Oct 15, 2005 | 04:06 AM
when you suck it thru the brake boost and give the throttle a little tug every now and then to keep the motor from choking. then some smoke should be spewing out for a while.
Old Oct 16, 2005 | 06:39 AM
loup05's Avatar
well i only revved the engine twice after puttin in the sea foam i saw smoke come out but not as much as other members claim to come out of their tail pipe. i turned the car off came back 30 min later.
The car started fine. i reved it to see if smoke came out but nothing. i ran it like hell in the street but still no smoke.
Do you think i idnt use enough sea foam? i think i used like half a bottle on the vaccum valve and the other half in the gas tank.
Old Oct 19, 2005 | 10:26 AM
loup05's Avatar
Default Re: (loup05)
bump
Kennethbtaden
May 13, 2017 01:28 AM
turbotime
Oct 20, 2006 12:03 PM
coreytheblade
Aug 20, 2006 11:27 PM
amej8
13
Jul 7, 2006 04:24 PM
amej8
Jun 3, 2006 01:50 PM
