If I was to get an engine swap, which motor should I get?
Old Oct 14, 2005 | 08:52 AM
integracura's Avatar
Default If I was to get an engine swap, which motor should I get?
I have a 1.8L non-vtec LS motor right now.
What should I do
Old Oct 14, 2005 | 09:00 AM
1997GS-R's Avatar
are you going N/A or plan on F/I??? If you are going N/A get the Type R motor...if boosting..get the GS-R
Old Oct 14, 2005 | 09:07 AM
blackdelslo's Avatar
Default Re: (1997GS-R)
yeah man it all depends on your budget and what you want to do.
Old Oct 14, 2005 | 09:19 AM
cannan's Avatar
Default Re: If I was to get an engine swap, which motor should I get? (integracura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1.8L non-vtec LS motor right now.
Keep the LS motor and go TURBO!!
Old Oct 14, 2005 | 09:40 AM
but i have like 155k on my car is that a good idea though
Old Oct 14, 2005 | 09:47 AM
93_teg_CT's Avatar
Default Re: (integracura)
Rebuild it and go lower compression and boost more!
Old Oct 14, 2005 | 10:03 AM
cannan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">but i have like 155k on my car is that a good idea though</TD></TR></TABLE>
Honestly if you don't have some fairly deep pockets or good mechnical skills I would just go a basic GSR swap. Turbo can be alot of tuning dollars and repair bills if not done correctly the first time
Old Oct 14, 2005 | 10:19 AM
shamoo's Avatar
Will you make something up for me please?
Mileage is definitely not a good indicator of a motor's condition/reliability. You need to check if it can hold good compression, and the leakdown numbers are good.
A motor could go bad at 10K miles or 300K miles.
In any case, like stated above, figure out the goals of your car first, then determine your budget. Then go from there.
Old Oct 14, 2005 | 11:50 AM
boostjunkie757's Avatar
bah.
just turbo an R motor...
Old Oct 14, 2005 | 12:10 PM
FULLY_BUILT_NA's Avatar
b20vtec
Old Oct 14, 2005 | 12:18 PM
cannan's Avatar
Default Re: (FULLY_BUILT_NA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLY_BUILT_NA &raquo;</TD></TR><TR><TD CLASS="quote">b20vtec</TD></TR></TABLE>
Cause that is the most reliable motor, and cheap to build
Old Oct 14, 2005 | 12:24 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
dude, do an LS-T SO much more potential...otherwise, my vote goes to the ITR egine.
Old Oct 14, 2005 | 12:26 PM
ecks_fourttwo's Avatar
Default Re: If I was to get an engine swap, which motor should I get? (DAantagonist)
keep the ls and go ls/vtec...
Old Oct 14, 2005 | 12:39 PM
riceball777's Avatar
Default Re: If I was to get an engine swap, which motor should I get? (RevHard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RevHard &raquo;</TD></TR><TR><TD CLASS="quote">
Keep the LS motor and go TURBO!!</TD></TR></TABLE>
a stock ls with a cheap $1000 junk yeard turbo will be way faster than a type r and ls long blocks are only a few hundred if it blows
Old Oct 14, 2005 | 02:54 PM
sir boostalot's Avatar
Default Re: If I was to get an engine swap, which motor should I get? (riceball777)
Do a rebuild with custom turbo. ITR is not worth the money to spend in a Teg. U wont get nearly the power unless u go turbo.
Old Oct 14, 2005 | 04:11 PM
Default Re: If I was to get an engine swap, which motor should I get? (sir boostalot)
put in a USDM d15 non vtec. Put on a ebay intake, obx header, 3" piping with 3 foot exhaust tip and youll be crazy fast. Just make sure you have a bigger intake to back up all the exhaust leaving the engine.
Old Oct 14, 2005 | 05:42 PM
ghostrider dc2's Avatar
Default Re: (boostjunkie757)
gsr all the way! for boost or N/A
type r ......eeeeeeh pointless for the absurd ammount of money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 &raquo;</TD></TR><TR><TD CLASS="quote">
its totally pointless , gsr its got better potential IMO for boost
ls/vtak =id stay away for the money and trouble .
if you want boost stay w the ls ,buy pistons and rods , and p/p the head; or get a gsr engine.
if you wanna stay n/a then you can opt to get an r .
Old Oct 14, 2005 | 07:11 PM
vladd's Avatar
Old Oct 15, 2005 | 06:41 AM
Cliffjumper2's Avatar
if you are going to build the motor, don't waste your money on a itr motor; buy the gsr motor.
If you are going to leave it stock, get the itr motor
Old Oct 15, 2005 | 06:48 AM
GolfIVTyBiggums's Avatar
Default Re: If I was to get an engine swap, which motor should I get? (Cliffjumper2)
Do not rebuild your ls, it will cost a million dollars. If you want to go ls-t, buy a new longblock. However, a stock gsr motor will probably be 5 times more reliable and just as fast as your 7psi ls-t motor. Of course, you could get a new ls longblock, and then get a zex kit for it, and spray a 50 shot when you need it. Reliability, speed, cheap, almost too good to be true. My 2 cents.
Old Oct 15, 2005 | 10:49 AM
halozero's Avatar
Default Re: If I was to get an engine swap, which motor should I get? (GolfIVTyBiggums)
not to steal the thread... but if i had a b16a sir ii and wanted to go NA would it be smarter to buy an ls block and go ls/vtec or a b20 block and go b20vtec or just opt for the r... tho i really want the k24/k20...
looking for reliability with power.
lovebench
Jan 13, 2007 06:10 PM
TeenyTymer69er
22
Dec 21, 2005 12:41 AM
For_Sale
Sep 5, 2005 03:40 PM
JDMVTEC
Dec 9, 2003 06:50 PM
LSpimpTEC
15
Aug 13, 2003 09:37 PM
