Rocket Motorsports M22 advice.....HELP PLEASE
Old Oct 13, 2005 | 03:54 PM
doublek's Avatar
Default Rocket Motorsports M22 advice.....HELP PLEASE
I recently got me some Rocket Motorsports M22x cams........
I thought i was going to be able to put them in my ls/vtec this weekend.........not sure now.
I have a first gen 16 head. I recently found out that i wont be able to use these cams with these LMAs. Ive also heard that they recommend getting new rocker arms.
CAN ANYONE CONCUR? IS THIS TRUE?
What should i do? What LMAs do i need to use? New rockers as well?
https://honda-tech.com/zerothread?id=1401412
THANKS FOR ANY HELP
Old Oct 13, 2005 | 03:58 PM
asubennett's Avatar
Default Re: Rocket Motorsports M22 advice.....HELP PLEASE (doublek)
New LMA's for sure. Stock rockers are fine though. I have stock rockers on M24X cams.
Old Oct 13, 2005 | 04:03 PM
doublek's Avatar
Any particular LMA you recommend? Or just any b series LMA newer then the first gen b16?
What do you use?
Old Oct 13, 2005 | 04:05 PM
PURPLETERROR aka BIGMATT's Avatar
I believe brad at rlz can mod your old ones, or you can buy new itr or gsr lma's, or use the prelude lma's with a shim washer, or you can buy a set of my gsr lma's i have fs
Old Oct 13, 2005 | 04:11 PM
doublek's Avatar
What is the real diffrence in LMAs?
Movement restriction? Clearances?
Old Oct 13, 2005 | 04:29 PM
Default Re: (doublek)
spring pressure, and size of the piston that the middle rocker rides on
Old Oct 13, 2005 | 04:32 PM
doublek's Avatar
Im using RM gen 1 springs and retainers now.
I have a set of the gen 2 brand new but rocket recommends sticking with the gen 1s
Old Oct 13, 2005 | 04:36 PM
DonF's Avatar
Listen to the Mfg., not the internet.
Old Oct 13, 2005 | 05:28 PM
itralex's Avatar
Default Re: (DonF)
you'll need new LMA's cause the gen1 b16's are too small
i'm currently running prelude LMA's with washers from EKhatch and so far so good
Old Oct 13, 2005 | 05:31 PM
VtecKiDD's Avatar
Default Re: (itralex)
uhhhhh
i had a 1st gen B16 head on my old motor, i had rocket valvetrain and m22s.
never had a problem...............
Old Oct 13, 2005 | 05:32 PM
Humble Performance's Avatar
I used stock LMA for a while now , no problems. Managed to run 11.80 @ 113 mph with a LS v-tec with ctr pistons (81mm) and some M22's !
Stock head NON ported.
Old Oct 13, 2005 | 05:54 PM
doublek's Avatar
Default Re: (8secEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">uhhhhh
never had a problem...............</TD></TR></TABLE>
JEEEZZZZ!!! HA. NOW IM CONFUSED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8secEg &raquo;</TD></TR><TR><TD CLASS="quote">I used stock LMA for a while now , no problems. Managed to run 11.80 @ 113 mph with a LS v-tec with ctr pistons (81mm) and some M22's !
Stock head NON ported.</TD></TR></TABLE>
You had a 1st gen b16 head with stock LMAS?
Old Oct 13, 2005 | 06:13 PM
VtecKiDD's Avatar
PM ROCKET or email him and ask him directly.
I personally ran my 1st gen b16 head to 9700rpms, it has stock LMAs and stock rockers, both 14 years old.
I had RM valvetrain and M22X camshafts.
Old Oct 13, 2005 | 07:07 PM
92Jspec's Avatar
hey 8seceg,
what head are you running on that LS-V?
Old Oct 13, 2005 | 07:42 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Stock rocker arms are fine. They just need to be inspected if they have a lot of mileage.
There have been many instances where 1st gen b16 LMA's have caused major problems. You will find them if you search. Rocket isn't the only one to bring this up, Omniman has talked about this as well as many others. Its not guaranteed to cause a problem, but the risk is greater.
I don't have a lot of time to search, but I think they have some discussion about it on this thread: https://honda-tech.com/zerothread?id=566420
IIRC, there was a thread on RM that described this in detail. We might have to get Rocket open it up. I will try to get back to this thread when I have more time.
Old Oct 13, 2005 | 09:36 PM
Toadfart's Avatar
Default Re: (rochesterricer)
Not to hijack the thread, but can someone verify the part number for the Prelude LMAs to be 14820-PCB-003? Thanks.
Dan
Old Oct 14, 2005 | 01:17 PM
Default Re: (92Jspec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92Jspec &raquo;</TD></TR><TR><TD CLASS="quote">hey 8seceg,
what head are you running on that LS-V?</TD></TR></TABLE>
1st Gen B16a head.
si0385.
May 12, 2006 04:43 PM
Egone
Feb 9, 2005 08:48 AM
grey16
Mar 9, 2004 09:02 PM
c1civic
Dec 4, 2003 12:25 PM
juicy.koreans.suck
Mar 7, 2002 07:29 PM
