Search Down: Civic radiator Which hoses to buy?
I've got a half core radiator from a civic for my 94 GS-R. Just wondering which radiator hoses will work for the small inlet and outlet on the radiator.
for the upper hose, you can use the stock gsr upper house and cut it about 1.5"-2" at the end that goes into the block.
worked for my friend.
the only problem is you need to make a mount for the bottom of the smaller radiator
the lower hose should be the same (stock gsr).
did you get a fluidyne?
No it's the $89 aluminum peice from somebody on the board. It isn't mine it is actually for a car I'm doing a turbo install on. I'll give it a try and let you know if it works. I kinda remember reading something about using Del Sol VTEC hoses for a better fit. Thanks for the info.
thats what i did for my friends gsr, he bought a fluidyne half core (civic) radiator and we just cut it a little and it worked fine
is the 98+ LS have the same length of hose as the GSR? gonna be doing this very soon also for my LS-T setup. assuming that the hose is the same length, then all you have to do is cut the upper hose about 1.5-2.0 inches? thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR »</TD></TR><TR><TD CLASS="quote">is the 98+ LS have the same length of hose as the GSR? gonna be doing this very soon also for my LS-T setup. assuming that the hose is the same length, then all you have to do is cut the upper hose about 1.5-2.0 inches? thanks!</TD></TR></TABLE>
yea, all stock integra b-series radiators are the same.
helpmycivic
27
Feb 24, 2007 11:51 PM
Flamenco-T
Feb 25, 2003 12:53 PM
