JUN flywheel intall semi-retarded friend needs to know
what is the proper way to install the flywheel is there a propper way to install the 11lb JUN B motor flywheel or do you install it the same way you would install a factory flywheel i know this is a dumb question but my semi retarded friend is trying to tell me there is some special way to insatll the flywheel thanks agian for you help
You just install it like you would the normal flywheel. Tighten all the bolts hand tight and then torque them in the pattern indicated in your cars shop manual. If you don't have the manual torque them down in a star pattern.
lilo_goki
24
Mar 18, 2008 06:37 PM
