damn crx
Ok, check your wiring. Then you can also check if the solenoid works. "Use a wire and touch the one end to the + battery post and then to the solenoid wire. You should be able to hear a distinctive click." I got this from another post made by Kamin. He was having the same problem and that was one of the troubleshooting techniques he used.
05 S2K Stoner
Oct 28, 2004 06:39 PM
