check engine code 43/cel code 43 ODB 1 please help
Old Jul 7, 2003 | 08:30 PM
Cole D's Avatar
Default check engine code 43/cel code 43 ODB 1 please help
Okay guys I did a search I couldn't find a good solid answer I know the code means malfunctioning fuel system. This is what I've done so far replaced fuel pump(walbro hp), fuel injectors, fuel filter, and fpr. I did notice when I pulled the fpr there wasn't that much fuel there and my plugs were white really white. I don't know what else I can do I did see on the search some people say the o2 sensor can cause this code what about a faulty ecu or vacuum problems. Last thing at idle my car blurps and poops very lightly though you have to really listen to it to notice.
Please someone help me out
Chris
Old Jul 7, 2003 | 09:43 PM
nevin's Avatar
i have same code and idle sound, I have a inline pump and fmu. the car drives fine though. the code usually comes on 1-5 mins after starting and driving around. anyone know how to fix this??
Old Jul 7, 2003 | 09:55 PM
blackeg's Avatar
Default Re: (nevin)
can someone please help fix this. i got code 43 too and its getting annoying...
Old Jul 8, 2003 | 12:09 AM
X2BOARD's Avatar
Default Re: (blackeg)
Bump on this 43... I get it on my D16 civic and my GSR.
Both of them also have a code 1 (primary O2) so I am replacing soon.
Old Jul 8, 2003 | 03:22 AM
Cole D's Avatar
Default Re: check engine code 43/cel code 43 ODB 1 please help (chriscoleman102)
C'mon somebody has to know how to fix this. Hey fellas, let's keep this thread going until we get something solid to go by
Chris
Old Jul 8, 2003 | 03:23 AM
Cole D's Avatar
bump
Old Jul 8, 2003 | 06:39 AM
X2BOARD's Avatar
Read this thread: https://honda-tech.com/zerothread?id=551714
Old Jul 8, 2003 | 03:06 PM
Cole D's Avatar
Default Re: (X2BOARD)
I read the thread informative, but I don't think that's it when I bought my car it threw a 43 almost immediately after I got it ,I thought no big deal the guy I bought it from said the check engine light comes on sometime and I was like okay I can fix it, but this is turning into a nightmare. My car has a farely new looking aftermarket O2 sensor in it already so either my O2 is bad or its not hooked up properly. Anybody have the wiring diagram for an autozone 02?
Chris
Modified by chriscoleman102 at 12:46 AM 7/9/2003
Old Jul 8, 2003 | 07:36 PM
Cole D's Avatar
Default Re: (chriscoleman102)
Okay guys I think I fixed my check engine light not sure just yet, but it looks very promising my whole problem was the 02 sensor.The sensor wasn't bad it was just wired up wrong. The guy I bought the car from replaced the 02 sensor to fix the car but all it did was make it worse. The universal o2 sensor was wired wrong I will include the right way to wire it up. For the rest of you guys I would say replace your O2 sensor but just make sure you hook it up correctly the car is idling alot better now I hope this finally clears everything up.
So chop off the connector on your old O2 sensor and crimp or solder it to the universal O2 sensor.
white - black (heater wires)
gray - green (ground)
black - white (signal)
The 2 white wires are for the heater and don't have a polarity.
Chris
Old Jul 10, 2003 | 08:25 PM
Cole D's Avatar
light has not come back on so I think its good
ef9itb
Nov 19, 2007 06:12 PM
curioso
Jan 24, 2007 09:39 PM
yz125rider21
Jan 13, 2006 10:12 PM
OBDI JEDI
May 7, 2003 05:06 PM
