jdm itr pistons in gsr
yes there good !specially for 91 octane (which is all that we have here in cali )
but also depends on the type of cams that you are planning to run .
like the skunk stage 3 lift 12.8 they recommend forge JE do to the deep valve pockets ,such high lifts
If you will be going through the expense of installing new pistons, you probably want to go with ones that will yield a higher comp. ratio. If not, you could look into a thinner headgasket and maybe some milling if you are planning on sending the head out.
JDM ITR will give about 11.3:1
JDM P30 will give about 11.8:1
USDM P30 will give about 11.6:1
It all depends on what cam you are gonna use.
If you want ITR pistons, save some money and get USDM ones.
SGT, why do the P30's yeild such a high compression ratio? Im looking on running TODA A's...would that be a good set up with those pistons? Here in SC we have 92-93 octane. I wouldnt run into any clearance or other problems running those would i?
TIA...
TIA...
no prob's at all with that setup.. p30's yield a higher cr due to the taller dome (they displace more volume).. check out my calculator for more oem combinations
spec A cams would be good with mid-11 compression ratio
Larger cams with more overlap effectively reduce dynamic compression ratio.
So to make up for that you have to increase the static compression ratio to
compensate.
compensate.
civic si = p30
PR3 was the old 1g b16a. after 92 the b16a code changed to p30 due to some
updated parts. The JDM compression ratio is 10.4 in b16a from 1992+ while
the older PR3 and USDM P30 are still 10.2.
The compression is more in a 1.8L due to the increase in stroke, the same reason
why a 10.8:1 civic R piston will yield 12:1 or more in a 1.8.
The main reason why the numbers are higher, are due to the B18C head rather
than the B16A/R head
stonet149
12
Nov 2, 2008 09:29 PM
dc2_dude
Mar 27, 2007 09:59 AM
